 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Thanks Karl, That's clear ;) I'll get some photo printer paper. What size are your tiles? From your dairy I gather that you painted them after fitting?
some more progress: Real keel fitted:     I glued planking strips together and then sanded them to the required thickness to build wooden "in-fills" for the gallery support  Slots cut for the middle gallery deck
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Coming along nicely Stefan. TIS
hi stefan,I cut the tiles at 15mm x 5mm.I marked them up on 3 sheets of a4 phoyographic card,then used a pinwheel to get the rivets,try e_bay you need a fine tooth pinwheel.I got mine from a forum member(dorami) Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Thanks Gents! A couple of more pics to show what I've been up to: Where I sanded the hull back too much, some filler was required to smooth out the transition to the real keel  The gallery decks fitted & glued:  The rear gallery fitted & glued:  Inside view of the Gallery:
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Your build is coming along very nice thhere stefan. Great job
Hi Stephan, your lady is looking nice and clean and coming on nicely. keep up the ggod work. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi Stefan Great job MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Great job Stefan...she is coming along really well mate...keep the pictures coming... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi all, Belated blessed Christmas and happy new year to all of you. Managed to get in a good couple of hours on the Victory during the time that I was on leave. So as not to overload you, I'll post day-by-day pics of my progress: Double planked gallery support:  Rear gallery former:  False bow deck fitted and shaped to accept the temporary mast:
She is coming along brilliantly Stefan... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
fantasticaly clean and tidy build stefan, well done Come on you Jimmies
Great Matey keep it up “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Well done Stefan MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks lads! As promised, some more action: Getting a curve on the gallery side panels. It wasn't exact, but close enough to need only minimal adjustment on final fitting.  Fitting the gallery side panels:  I got cracking with planking the bow deck while the gallery side panels were curing. I didn't have a non-running marker, so I used a pencil to mark the edges of the planks
Top mouldings added to the gallery sides:  The middle starboard wale pinned:  Bottom view of the Gallery sides and the rear of the middle wales. There is a slight gap which I'll be filling with wood filler:  The planks on the bow sanded down. I cut the opening of the dummy bowsprit dowel with a knife before sanding it, on the picture you can see that it was cut back too much. The middle 2 planks have since been replaced and the hole shaped properly
Looks nice mate, Before Mr T says it... don't forget the extra hole in the bow. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
lol, thanks Jase! I was under the impression that one had to wait until the trim strips have been fitted to the stem? I'll get the cordless charging up!
Nice crisp clean build Stefan  Best wishes Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Great work Stefan...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
