Chainwale links thoughts Options
#1 Posted : 19 December 2011 20:11:45
Hello ship mates. has anybody come up with a better way of making the links under the chainwales? i dont like the fact they are not joined.
any suggestions appriciated BigGrin
#2 Posted : 19 December 2011 20:23:28
BigGrin Hi Jase
Just an idea if the wire is brass then u could try soldering/ brazeing the ends together,but a better way might be to obtain some brass tube of the correct diameter[ ie so it slides over the wire but is a good fit]then cut small lengths and solder/braze or glue to get a neat finish. Just an idea hope this gets the little grey cells jumping
PS, On the victory if the origonal chains are joined then they would have been hammer welded [ like all chains were made back then] by a blacksmith
#3 Posted : 19 December 2011 20:49:10
They're are not joined on the real ship
http://gallery.kitmaker....a/22154/HMS_Victory3.jpg
allanc62
#4 Posted : 19 December 2011 21:52:55
Here are a couple of photos I took of the channels
Hope they are of help
#5 Posted : 19 December 2011 22:29:36
BigGrin It would seem that some of the chain whale links are open and others joined as u can see from Mr T,s piks and the above examples, so i guess its what is more pleasing to you on your model or to go for the scale appearance as on the real shipLOL desisions desisions
PS As an after thought perhaps some of the chains were left open to give a spring/flex to the chain whales where more movement of the rigging was needed
#6 Posted : 19 December 2011 23:40:29
[quote=Tomick]They're are not joined on the real ship
http://gallery.kitmaker..../22154/HMS_Victory3.jpg[/quote]
Sorry Mr T thier is somthing wrong with that photo it may be a clever photo shop job but i dont belive that is the real victory. The gunport lids have nots under them, not the chain hoops?. My pics that i took last year show them all closed looped. confusing.
I was wondering about using the same proces but cutting the linck at the top so it would not bo so noticable.
#7 Posted : 20 December 2011 09:21:11
Looking at the image again I think your right, the knots on the port lids are a give away, its a photo of a model rather than being the real ship LOL
If you have the time an patiece you could close the joint with solder which wont show if your painting them black.
#8 Posted : 20 December 2011 21:39:27
I am painting so soldering may be an option I also think i will make the cut higher up rather than in the middle.
#9 Posted : 20 December 2011 22:09:25
Very convincing model though Mr T.. LolLOL LOL LOL
This page was generated in 0.103 seconds.
