Making the Admirals Companionway cover. Options
#1 Posted : 11 December 2011 21:50:48
In front of the Captains cabin (rear partition on your model) is a companionway to the Admirals dining room. There is nothing included in the kit for this but I have decided to make the cover as seen on the Victory today, and its not hard at all...
To make the cover you will need a strip of 4x1.5mm cut to the following lenghts
4 x 8mm
2 x 17mm
2 x 12mm
and a panel pin
Step 1. take one of the 17mm strips and glue the 4 8mm lengths along one adge as per pic below:
step 2. once dry gently sand theends level of the 8mm strips and glue the secound 17mm strip as per pic below
Step 3. ensure both ends are level and glue the 12mm strips to each end
step 4. Once dry gently sand all sides till smooth. sand the frame down to about 2-2.5mm deep so the lid is not to proud on the deck. finaly drill a gide hole for the pin. cut pin to 2mm long and glue into hole
Job done.
all pictures authors collection.
#2 Posted : 11 December 2011 23:09:36
Good stuff JaseBigGrin Cool
daffy09
#3 Posted : 12 December 2011 00:11:49
Good one Jase, I'll give that a try. Would the colour be Walnut?
PS. Did you get the PM I sent to you regarding the photo packs?
Happy building
Daffy09
#4 Posted : 12 December 2011 08:09:47
Hi Daffy yes wallnut.
yes I have your message and will send out next couple of days when i get my laptop back from my daughter lol BigGrin
jonny7england
#5 Posted : 12 December 2011 09:04:34
Brill Jase...Nice one mate!!...Love
daffy09
#6 Posted : 12 December 2011 13:16:23
Thanks Jase and Seasons greetings to you and your family
Happy building
Daffy09
riff-raff
#7 Posted : 22 December 2011 14:16:19
Where exactly would this part fit on our models?
Thanks
Built:
#8 Posted : 22 December 2011 17:36:36
Position of the cover is in front of the rear cabin partition (supplied in your kit as a solid piece of wood. As per my pic above.
If you can hold on a few days I will be laying out the cabin area over Xmas there is also a chang to the partition positions as they are to far forward.
This page was generated in 0.102 seconds.
