26 Pages «<1819202122>»
MWG build diary of the Bark HMS Endeavour Options
Hans
#381 Posted : 02 December 2011 14:21:51
Good quality build as expected from you now Mike.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#382 Posted : 02 December 2011 16:46:00
Thank you Hans, very nice of youBigGrin
#383 Posted : 07 December 2011 13:07:39
ISSUE 34 THE TWO HATCHWAY HOODS
I have stained the parts for the two Hatchway hoods,I am keeping the oak theme through the Deck and the Deck Hatchways, I like the look and it works for me.:-BigGrin
#384 Posted : 07 December 2011 13:10:08
ISSUE 34
I hope you like the effect, comments welcomeBigGrin
#385 Posted : 08 December 2011 09:38:00
ISSUE 46
Hi Team, received this weeks issue today, its all about how to finish the capstan, seems to me we should be doing more important things like finishing the Hull!!!Blink However, where the magazine shows the position of the Capstan, it appears to me the crew would not be able to get round to pivot the Capstan, maybe I am missing something(it would`nt be the first timeHuh )your comments would be appreciatedBigGrin
alantait
#386 Posted : 08 December 2011 10:06:44
Hi mwg, yes i thought so aswell, even the magazine states how awkward it would have been to use and after looking up an official tour in 3d of the original it does look correct. the only difference is where we have a raised sylight and companion way, the original seems to have the companionway and grating, also the locker infront of the wheel seems to be to either side of the wheel on the web view.
alan
http://www.google.co.uk/...vdX-aG3AfDPOr1CMkOvLPbvw
current builds
#387 Posted : 08 December 2011 11:48:23
Good post Alan thanks for that, more food for thought, may go for grateing!!BigGrin The Anatomy of Ship Endeavour commingDrool
Trotsky
#388 Posted : 08 December 2011 13:05:20
From my recolection of a visit to the replica the Hand Spikes clear both the Skylight and the Companion Capping ...the Capstan which had a whelps chocks a pawl type ratchet system could be operated by not moving with the capstan spikes but remaing in place and passing them from hand to hand...ummm not sure if that sounds right but thats how it was explained to me....I have drawings if required....
H.M.S Victory
H.M.S Victory X Section
H.M.S Surprise under the bench
D-51
alantait
#389 Posted : 08 December 2011 13:49:13
hi trotsky, yes it does mention that a ratchet system had to be employed because of the tightness of space, but wouldnt like to have to use this in the kind of weather they encountered or evan what we are experiencing outside my house just now ( gusts of 60 mph and constant 39mph)Scared
current builds
Trotsky
#390 Posted : 08 December 2011 15:27:40
Well the News just advised that it is heading South and will reach the SE soon so I guess I need to batten down the hatches...Stay safe Alan
Regards David
H.M.S Victory
D-51
#391 Posted : 08 December 2011 17:57:12
Hi David thank you for your contribution, drawings sound great I wonder if it is possible to obtain a copy, I would be happy to pay you somthing for your trouble, if it is possible please PM me.
I would like to get this build as accurate as possible, so any help would be appreciatedBigGrin BigGrin
Trotsky
#392 Posted : 08 December 2011 22:17:33
I will do some scans ...but most of them are in Anatomy
H.M.S Victory
D-51
#393 Posted : 08 December 2011 22:26:29
No problem then David I have the book on the way, but thanks anywayBigGrin
#394 Posted : 13 December 2011 15:12:20
ISSUE 46
Hi Team I have stained the 5mm x 2mm I require to fit the pieces to the Capstan, I did not use a plank that comes with the build because the grain is not tight enough and does not take the stain so well, I used a plank left over from the Victory :-
#395 Posted : 14 December 2011 17:59:59
ANATOMY OF THE SHIP
CAPTAIN COOK`S ENDEAVOUR
Well every body I have not got any excuse now!!!
My better half has purchased the above book for me, MR T is right, it is fantasticDrool BigGrin I have all the information I need nowBigGrin
Dontshootme
#396 Posted : 14 December 2011 20:02:45
It is a very good book Mike,I have it already for when I start my Caldercraft Endeavour,got 1 for Bounty,Hood & Victory as well.Excellent books every one of them.
#397 Posted : 15 December 2011 15:05:48
Thanks Rob for your endorsement of the book,it really is MegaBigGrin
#398 Posted : 15 December 2011 23:48:01
ISSUE 47 THE STERN
As you all know I have not used the stern formers from eaglemoss I preferred to use balsa wood to form the Bow as well as the Stern.
this enabled me to get a shape on the stern more authentic to the drawings (which has been born out by the ANATOMY OF THE SHIP)this shape is broader where the stern planks will be fitted.
I have now planked the stern as per the instructions, but I will be enlarging the Helmport on the Hull more in keeping with the drawings when the adhesive is cured. here are the photos comments are welcomeBigGrin :-
#399 Posted : 16 December 2011 00:16:13
ISSUE 47
The planks fitted:-
#400 Posted : 16 December 2011 01:15:38
ISSUE 47 PLANKING THE TRANSOM
Sorry missed this one showing the curve:-
Guest (5)
