Cannons Options
riff-raff
#1 Posted : 06 December 2011 15:51:53
How many "real" cannons do we get for the lower deck? or are we getting "dummy" cannons for the areas that are not seen from the inside?
Thanks
Built:
#2 Posted : 06 December 2011 17:25:33
Hi Riff Raff,
You get 42 actual cannons, no dummies. But I only used 36 as that is the correct amount for the HMS Surprise.. 24 on the lower deck and 12 on the Top deck.
Hope that helps.
riff-raff
#3 Posted : 06 December 2011 17:40:19
Thanks Chris
I have just started to make the inner gun ports and wondered why it only says to frame between frames 11 & 17.
Dave
Built:
#4 Posted : 06 December 2011 18:18:48
Hi,
The reason is you don't see the inner wall past those ribs once the upper deck is on. But I decided to do the full length of the inner wall.
Chris..
riff-raff
#5 Posted : 06 December 2011 20:30:22
Yeah I noticed that Chris - I have been following your build with great interest.
I think I'll do the same if you don't mind me pinching ideas BigGrin
Built:
#6 Posted : 06 December 2011 20:48:40
Pinch away mate. I glad you like the way I have done these mods. BigGrin BigGrin
This page was generated in 0.150 seconds.
