Bow Height Options
Smuggler
#1 Posted : 30 November 2011 19:22:15
Bit confused here.
Where should the finished bow be level to in relation to rib 9?
Should part 16 of the bow be level with the lugs or the main part?
Any help would be appreciated.
I smile because i have NO IDEA whats going on :)
#2 Posted : 03 December 2011 02:06:39
BigGrin Hi Smuggler
the bow height should be level with the bottom of the luggs in line with the planking after sanding down part 16 of the bow parts to the correct chamfer,if you look on tomiks oficial build you can just see what im talking about, sorry it took a while to answer ur querry hope this helps
Smuggler
#3 Posted : 03 December 2011 19:12:48
Blushing Got you now, i was confused as to what part of part 16 should be flush with the planking.
Thanks for the advice, will continue now BigGrin
