Issue 86 Contained Wrong Part Options
Son of Bulwark
#1 Posted : 03 December 2011 11:36:56
Hi Shipmates! Cursing
I was about to start issue 86 fitting the beakhead frames when I found that the pack contained the wrong part, I had the larger frame and two of the smallest frames instead of the correct three frames. Cursing Cursing Cursing
If I was you I would check your issue 86 in case you too have the same wrong part. I hope this is a one off and the rest of you don't have this problem.
I can't get on with the bow now, so I will have to find another job to do on the ship! I'm so mad about it but these things happen!.
#2 Posted : 03 December 2011 12:19:29
Oops, at this stage it sounds like a one-off pack error, I've checked a couple which are ok.
This page was generated in 0.078 seconds.
