22 Pages «<45678>»
Stefan's build Options
StefanDV
#101 Posted : 18 October 2011 16:10:13
karl1113 wrote:
hi stephen.yes it were me that put up that tip 'bout painting then wet & dry rub down,at this stage I used 600 grade WET,much easier to wipe down,
and if continued by filling and painting you will get a glass like finish,
so you have to determine how far to go,lovely job so far.well done.
You're right Carl I think I saw it on your Black Pearl Build. since I started I might just as well go the distance and finish it properly
StefanDV
#102 Posted : 18 October 2011 16:11:15
Hans wrote:
Drool Well done Stefan, looking absolutely brilliant. You can and must be proud of your work. You deserve it.DroolDrool Drool
Thanks Hans, much appreciated
#103 Posted : 18 October 2011 17:23:51
BigGrin your doing fine m8 just remember all that sanding/preparation is what will make a top noch build
StefanDV
#104 Posted : 18 October 2011 18:56:33
Thanks Andy. Since sanding has to take place outdoors, I can only work over the weekends (when it's also expected that the to-do list should shorten) Wink
StefanDV
#105 Posted : 24 October 2011 09:53:22
A quick update on where I got to over the weekend:
After getting a fair bit of sanding done:
I saw a couple of uneven spots and holes left by the removal of the nails and proceeded to fill them with wood-filler
Now to sand some more BigGrin
Hans
#106 Posted : 24 October 2011 11:36:40
Good going. She's looking real good. At least I know what suffering is ahead of me.[Huh Huh
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
StefanDV
#107 Posted : 29 November 2011 08:22:12
Hi All,
It's been more than a month since my last post!
Sanding down the Port side:
And the Starboard side:
Now just the sanding above the waterline to be done and then a nice rub-down with P800 and P1200 before I can complete issue 39
Gerrit
#108 Posted : 29 November 2011 09:38:32
Hi there
Seems like the good old Elbow Grease has been quite busy...
Looking good Hang in there
It will be worth everything
Gerrit
jonny7england
#109 Posted : 29 November 2011 10:06:54
Looking real nice, real nice in deed...Great job on the hull!! ThumpUp
Hans
#110 Posted : 29 November 2011 10:07:58
HI Stefan
You have obviously spent a lot of time on her and it is payng off. She's lookng real good, all credit to you. Keep going and keep the pics coming
Rgds, Hans
tom.ganc
#111 Posted : 29 November 2011 10:45:22
Hi mate. She is looking really good. Fantastic job with the hull, looks very smooth.
Are you planning to paint it/copper plate the hyll?
Happy modelling.
#112 Posted : 29 November 2011 10:51:34
Hi Stefen,
She is a credit to youBigGrin Cool
StefanDV
#113 Posted : 29 November 2011 12:19:26
Gerrit: Quite a large amount of elbow grease, and there is still a little bit to do.
Jonny, Hans, Mike: Thanks gentlemen- I trust that the effort will be well spent. That is the good (and the bad) thing about painting the hull - you can't stop until it's done.
Tom: After seeing all the hulls that have been copper tiled, I would love to, but the tiles aren't offered in South Africa. I'll be painting unless I can convince 15 or so members to send me the tiles that they did not use Sneaky
#114 Posted : 29 November 2011 13:34:04
hi stefan,have you considered the alternative,have a look at my build,cost me nothing to do,and does look really authentic,just click on my link under my ugly mush.all you need is a pin wheel,and thin card.
Atholm
#115 Posted : 29 November 2011 14:50:30
Hi Stefan
The effort is paying off keep up the good job.
Happy building
Athol
StefanDV
#116 Posted : 29 November 2011 15:15:38
Atholm wrote:
Hi Stefan
Happy building
Athol
Thanks Athol!
StefanDV
#117 Posted : 29 November 2011 15:16:43
I Karl,
Don't know why I haven't seen this before - it's brilliant! What thickness card did you use?
#118 Posted : 29 November 2011 16:39:59
hi stephen,normal a4 card,or you can use photographic card.
StefanDV
#119 Posted : 29 November 2011 21:28:39
When you say A4 card, is it A4 paper? (Sorry for not knowing the correct term)
#120 Posted : 30 November 2011 00:09:43
hi stephan,the A4 is the sheet size,I used photo paper,which is a card.the stuff you print your pics on from a computer printer.
Guest (6)
22 Pages «<45678>»
This page was generated in 0.174 seconds.
