11 Pages «<23456>»
MWG BUILD DIARY OF HMS ENDEAVOUR LONGBOAT Options
#61 Posted : 20 November 2011 17:46:04
ISSUE ONE PLANKING
I numbered the planks and fitted in place with adhesive Starboard 1 and 2.
You will see the stealer fitted to the keel and two wooden supports made from offcuts of planking these give support to the bow and Keel:-
#62 Posted : 20 November 2011 17:51:22
BigGrin Great looking build there MWG
jonny7england
#63 Posted : 20 November 2011 17:53:23
Spot on Mike...I am in awe of your work, as usual mate...Love ThumpUp
#64 Posted : 20 November 2011 18:26:10
Thanks Alan and Jonny for your further words of encouragementBigGrin Cool
#65 Posted : 20 November 2011 18:31:06
ISSUE ONE PLANKING
I have not been to critical with the ends of the planking in this proccess (you will see some splits on the ends) it is being double planked, on the second planking I will take alot more careBlushing Here are the last photos on this session questions and comments welcome:-
Hans
#66 Posted : 21 November 2011 09:57:47
Now now Mike, no cheating.BigGrin BigGrin . Looking good anyway
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
catman275
#67 Posted : 21 November 2011 13:51:02
Hi MWG,
I found that bows were the difficult part of the planking, but the second layer hid up any defects in the first.
I fitted all the small pieces afterwards, I could wedge them in tight and they would stay in without any nails.
Plenty of soaking and using a soldering iron was my method.
(my ends split as well).
cheers Peter
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
#68 Posted : 22 November 2011 22:19:37
ISSUE ONE PLANKING
The 4 planks are fitted on the base of the Hull, and partly sanded:-
#69 Posted : 22 November 2011 22:23:19
The next job is to do it all over again.
The next time you see photos the Hull will be single planked.
Questions and comments weicomeBigGrin Cool
#70 Posted : 29 November 2011 00:34:15
ISSUE ONE PLANKING
Still at it, thought you might like to see progress photos:-
#71 Posted : 29 November 2011 00:38:53
ISSUE TWO
I received the second of three Issues today, I am very impressed with the quality of the wood (all different kinds and colours):-
Foz
#72 Posted : 29 November 2011 19:53:28
Shes coming along real nice there MWG, a credit to you. Look forward to seeing the progress.
Foz
#73 Posted : 30 November 2011 08:03:09
Thank you FozBigGrin Cool
#74 Posted : 30 November 2011 19:33:55
BigGrin nicely done there m8, have you decided what wood your using for the secondary planking yet
#75 Posted : 01 December 2011 09:45:57
Hi Andy Maple on the Top around the Gunnels and Mahogony for the rest all 0.5mm thick by 4mm wideBigGrin
#76 Posted : 01 December 2011 18:56:07
BigGrin I like itLOL
#77 Posted : 08 December 2011 18:22:00
ISSUE 1 PLANKING
Hi Team I have finished the first planking, I thought you would like to see the photos before I remove the final trenails and sand the HullBigGrin Comments welcomeBigGrin
#78 Posted : 08 December 2011 22:16:29
ISSUE 1 PLANKING
I have started to sand the Hull and found some undulations:-
#79 Posted : 08 December 2011 22:23:22
ISSUE 1 PLANKING
So what I useuly do in a situation like this is fit a piece of planking over the undulation, as this model is double planked its not too serious,if it is a single planked model like the Victory I would take more care, but having said that it can sometimes look like a repair on the model and look authentic.
All the pieces you see in the photos have to be sanded when dryBigGrin
#80 Posted : 09 December 2011 17:04:30
ISSUE 1
Well Team the repairs have been made and the sanding is finished:-
Guest (5)
11 Pages «<23456>»
This page was generated in 0.287 seconds.
