Very nice work as usual, and great info re the fillers thanks Andy MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Thanks again for the encouragment MWG Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All pack 6 arived in the week,so iv been fetling since then getting pieces to fit arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Added the rear parts as instructed then used some filler on the gaps,some filler filling still needed around the bridge area arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 The next two pieces needed a fair bit of work but got there in the end[not quite finished yet] arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Heres the bridge added to see how much i need to remove for a good fit,not a great deal to remove here, heavy sigh of relief  .Im not too happy with the paint job on the bridge so il have to redo i think arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi all a few more pics of the build so far arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Now to make the 4 grills,i ussaly cut the mesh a little larger than specified in the instructions then file back to the corect dimensions.Also included is the card template i used to position the front grills,cut it to the dimensions specified the use to get the cross hair position by fliping up the bendy bit regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Heres a few pics of the results so far  ,now onto a more relaxing propasition the planking arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi all some more pics of the central strakes build, still a bit rough as its before any sanding has been done.  But a word of warning here for this section of the build in the download instructions[pg 71-72]its a compleat hash.It says take a strack [no7] and attach it from frame 6 to 12 [the wood provided isnt long enough to do this anyway],then to take the second strake [no7] and attach directly below it, ignore these instructions. Instead follow tomics official build diary and attach strakes [no7] from frame 5 to 9 then the second strake [no7] to frames 9 to 13 [not frame 6 to frame 14 as stated in the download instructions]then fill in below with strakes [no6].Had me scratching my head for a while till i read an old post [pg3] of another builder who had the same problem,hope this helps bulders who are building this now Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Still have 30 strakes over so il be using these to close up the rest of the hull, more pics when iv used these up regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi all heres the stern fully closed up,il do the bow next all comments are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi all Some more pics of the stern/mid sections after a rough sanding, next to compleat the bow/forward section. All coments are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Fantastic Andy MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Thanks very much for the nice comment MWG Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
She's coming on well Andy and taking shape nicely
 Thank you Mr T im enjoying this build emmensly Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 A few more pics of the hull  last 1s a bit out of focus sorry+ bad light sorry arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
The Hull is really taking shape is that the Akagi in the background? MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Hi MWG yes thats the Akagi heres a pic of both,and thanks for the comments as it sometimes feels like the Yamato build has been forgoten about[ plenty of views but not many comments, mainly yourself and tomic which are greatly appreciated by myself]. Il be posting the next instalment in the Akagi build diary as i got the latest package this week [pack 4] Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
