Looking absolutely brilliant Tom, a very time consuming task in deed,..and beautifully done!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
 Rank: Pro  Groups: Registered
Joined: 25/08/2010 Posts: 170 Points: 537 Location: Germany
Hi Tom,
really nice build and an inspiration to watch.
How did you get this intense caulking structure between the planks? Did you use a pencil or a black pen marker?
Cheers, TimmMy build diary hereCurrent Build:HMS Victory
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
Hi To
Your copper tiles are perfect. Very neat work keep it up.
Happy build and plenty of patients.
Athol
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
First of all thanks to anybody for comments. I will be stuck with this copPer for a while so you get to see diferent stages of it. Mr.Quist wrote:Hi Tom,
Cheers, Timm Hi Timm, The caulking is done by using black marker pen of the edges of planks. For decking I used 3mm x 1mm x 100mm wallnut planks treated with natural danish oil. I hope it helped.
Thanks for the info, Tom !!
tom.ganc wrote:For decking I used 3mm x 1mm x 100mm wallnut planks ...
Did you double-plank the deck or did you use the walnut instead of the suplied planks ?
Cheers, Timm
Mr.Quist wrote:Thanks for the info, Tom !!
Cheers, Timm
Hi Timm I double planked but didn't use planks supplied because they were too thick. If I put 1mm planks on top of the supplied ones all cannons would be too high up and barrels would'n fit the gun ports. Instead of that I used thin sheet of balsa. Just did it exackly the way as first two decks supplied in magazines. Then wallnut planks went on top if that. I hope that's clear enough :-) Happy modelling ;-)
 Hi Tom a very impresive and tidy build there m8 Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
tom.ganc wrote:Hi Timm I double planked but didn't use planks supplied because they were too thick. If I put 1mm planks on top of the supplied ones all cannons would be too high up and barrels would'n fit the gun ports. Instead of that I used thin sheet of balsa. Just did it exackly the way as first two decks supplied in magazines. Then wallnut planks went on top if that.
Hello Tom,
You convinced me. I am still not satisfied the way my decks looks like. And the way you did it sound much better to me. Just ordered my walnut strips. Thank you very much for that hint. Did you do the top decks the same way ?
Cheers, Timm
Mr.Quist wrote:tom.ganc wrote:Hi Timm I double planked but didn't use planks supplied because they were too thick. If I put 1mm planks on top of the supplied ones all cannons would be too high up and barrels would'n fit the gun ports. Instead of that I used thin sheet of balsa. Just did it exackly the way as first two decks supplied in magazines. Then wallnut planks went on top if that.
Hello Tom,
Cheers, Timm
Yes mate, all decks done that way.
Tom great minds think alike ,I have already purchased the balsa!!! well you know I can not live without it MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi again I've got another update of my copper plating. It is moving slovely ahead :-) Sorry for pics quality but it is from my mobile 1.  2.  Thanks for watchng. More to come soon :-)
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Nice!! Very Nice You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
Tom its looking fantastic!! the natural curves are very authentic, please keep everything as is, great stuff MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Looking good so far! The colour of the rest of the build realy sets off the copper tiles? Don't worry about running out of tiles I have probably got in excess of 300 left, as I made use of a lot of the off-cuts. I have probably tiled a little higher up the hull than was needed, my intention is to paint a thin copper arc over the lowest point of the lower wale. This will then finish off the water line, at the moment I am plating the rudder and carrying on with the masts and spars. If there is a particular part of the plating that you are unsure of please feel free to ask me? you may well come up with a better alternative but as I done mine already you now have a model to compare with. Keep up the good work and don't rush the tiles. Steve..
really nice neat paint job  is it spayed? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks for comments. I really enjoy tiling it. It takes ages but needs to be done. I still have quite long way to go but there is no rush :-) farrabass wrote:Looking good so far! The colour of the rest of the build realy sets off the copper tiles? Don't worry about running out of tiles I have probably got in excess of 300 left, as I made use of a lot of the off-cuts. I have probably tiled a little higher up the hull than was needed, my intention is to paint a thin copper arc over the lowest point of the lower wale. This will then finish off the water line, at the moment I am plating the rudder and carrying on with the masts and spars. If there is a particular part of the plating that you are unsure of please feel free to ask me? you may well come up with a better alternative but as I done mine already you now have a model to compare with. Keep up the good work and don't rush the tiles. Steve.. Hi mate. Thanks for comment. I'm fine with my tiling for now but I'm sure it I get stuck you will be first to know :-) Cheers
jase wrote:really nice neat paint job  is it spayed? Hi mate. All painting was done with brush. Just have decent brush and take it easy :-) Cheers
What a great job you've done there Tom...Looks fantastic...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Thanks guys. I've got little update. I'm in a really slow part of the plating... working around the waterline, etc It takes loooong time to move forward but an end effect is briliant. Have a look 1.  2.  Stay tuned
Guest (7)
