56 Pages «<1314151617>»
#281 Posted : 12 November 2011 11:17:32
ISSUE 11
I then proceeded to construct the stern parts as per the instructions.
what follows is a montage of the build instructions:-
#282 Posted : 12 November 2011 11:24:58
ISSUE 11
I used more glue than usual to give more support to this vunerable area (the glue will not be seen)
This is how she looks now, comments are welcomeBigGrin Cool :-
willie
#283 Posted : 12 November 2011 13:08:52
i do the same as you use more glue than needed then brush it in to the corners just before it dries
Tiswas
#284 Posted : 12 November 2011 22:40:39
Looking good Mike.
picked up my issue 11 today.
TIS
#285 Posted : 13 November 2011 06:26:55
Thank you TerryBigGrin Cool
#286 Posted : 16 November 2011 12:59:06
Received Issue 12 today, will post build laterBigGrin Cool
#287 Posted : 16 November 2011 20:05:49
ISSUE 12
This is what we received this week:-
#288 Posted : 16 November 2011 20:08:19
ISSUE 12
I numbered the parts:-
#289 Posted : 16 November 2011 20:10:31
ISSUE 12
Then I cut the pieces from both sides, trimmed and sanded them:-
#290 Posted : 16 November 2011 20:12:20
ISSUE 12
I then Glued the parts together as per the instructions:-
#291 Posted : 16 November 2011 20:16:19
ISSUE 12
It looks like a stealth plane????
I clamped the parts and put them away to dry, thats all for this weekBigGrin Cool
S2ksean
#292 Posted : 17 November 2011 13:15:07
A little disappointed with this weeks issue ya don't get alot. Still looking good tho MWG
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#293 Posted : 17 November 2011 19:01:55
Hi Sean now we know why it takes 140 issuesHuh Blink Glare
S2ksean
#294 Posted : 17 November 2011 19:19:47
Yeah. I thought it was 120
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Tiswas
#295 Posted : 17 November 2011 22:45:45
Could be that it's because there isn't much left of the frame to add, must be getting near the planking stage.
TIS
#296 Posted : 17 November 2011 23:15:51
You are probably right TerryCool BigGrin
#297 Posted : 18 November 2011 20:28:43
Its def 140 issuesCrying
comic123
#298 Posted : 23 November 2011 17:10:12
sorry to jump in on your build, but how long should a build board be for this buildBlink which I cannot wait to start.Drool
#299 Posted : 23 November 2011 18:05:29
Hi mike
Looking good. Looks like they are putting deck pieces in before the planning starts.
Ian
#300 Posted : 23 November 2011 18:41:12
Hi Comic my board (Dry Dock) is 115cm its a little short but adequate, if you want to be exact go for 140cm, hope that helpsBigGrin Cool
This page was generated in 0.564 seconds.
