re filler Options
bripfc
#1 Posted : 10 November 2011 16:26:55
hi all
this might be a silly question but what would you folks recomend to use as the wood filler? does it need to be flexable to allow for shrinkage. I am going to paint the model so it needs to be able to take the paint.BigGrin
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
#2 Posted : 10 November 2011 16:33:14
Hi in my opinion the best filler to use is RONSEAL MULTI PURPOSE WOOD FILLER obtain PINE NATURAL this filler is all so recommended by MR T and you can not get a better recommendation than that. plus the product works, and it sands with no problemBigGrin Cool
#3 Posted : 10 November 2011 17:22:53
Many use offcut saw dust with PVA
#4 Posted : 10 November 2011 21:16:38
BigGrin Some people use poly filler or the above mentioned products
Blue_Joe
#5 Posted : 10 November 2011 23:12:53
In all my joinery, if filler is required I tend to use 2 part ronseal wood filler as it is strong. However quite often, especially if colour matches are required then you can't beat the aforementioned sawdust and pva, just apply pva to area to be filled and then sand the surrounding area to auto mix the sanding dust created with the glue.
Either I would say would be perfectly good for this build as would the filler recommended by Mr T.
However I couldn't say I'd risk using polyfiller. Its not really designed for wood, definatly doesnt flex and will over time crack and probably fall out. I don't even use polyfiller in walls and I don't think its very good.
Sorry my 2p!
StefanDV
#6 Posted : 11 November 2011 07:43:40
I use a wood filler bought at the local hardware store.
Also wouldn't use Polyfilla
bripfc
#7 Posted : 11 November 2011 10:02:13
thanks everyone for the adivse i will give them a go dont get me wrong these are only small gaps to be filled, as it took me 3 attempts to get the planking right.still not completly hence the use of filler.BigGrin
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
Snorbitz
#8 Posted : 11 November 2011 14:13:37
Not sure if this would help but when it came to filling small gaps (very small), I put PVA glue into the gaps and then sanded the surrounding area with a fine sandpaper. The resulting dust stuck to the glue inbetween the planks and the excess glue was sanded off. However i'm no expert but I sure someone will correct me if i'm doing something incorrect.
If it ain't broke, don't fix it
Victory Build Log http://modelshipworld.co...p?t=12467&highlight=
willie
#9 Posted : 11 November 2011 16:10:58
try thin slither of wood if you can see through the gaps , plane or knife cuttings etc and sand down after thats what i do
Blue_Joe
#10 Posted : 11 November 2011 20:18:52
See my earlier post - Blushing Blushing Blushing
#11 Posted : 12 November 2011 09:50:27
LOL Just to clarify my earlyer post i said 'some ppl use poly filler' but forgot to add but i wouldnt recomend its use
Snorbitz
#12 Posted : 12 November 2011 09:51:42
LOL, I must remember to read all the posts.... Thats at least 2 of us that use the same method BigGrin
riff-raff
#13 Posted : 13 November 2011 11:48:52
I have tried mixing wood filler (wilkinsons home brand) with 50/50 PVA with good results.
Some fillers I have used in the past tend to fall out of the smaller gaps when sanding.
Built:
#14 Posted : 13 November 2011 12:01:03
Hi Riff
The ronseal filler copes with trenail holes with no fall out.BigGrin Cool
riff-raff
#15 Posted : 13 November 2011 19:01:30
Thanks MWG I will bare that in mind when I treenail the Suprise.
Built:
bripfc
#16 Posted : 14 November 2011 08:58:25
Thanks lads,
i went with the PVA and sawdust, this did the job. now thats down the other half can stop moaning about all the dust ive been making.
LOL LOL
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
#17 Posted : 14 November 2011 14:31:21
LOL Just say your recycling the dust m8LOL
RussG
#18 Posted : 24 November 2011 17:12:53
Have a look here:
http://www.cornwallmodel...k/acatalog/fillers.html
I use the super filler at the bottom of the page and wood! highly recommend it.
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
This page was generated in 0.230 seconds.
