Copper tillimg Options
nelson
#1 Posted : 06 November 2011 14:23:49
Hello everybody i am having real trouble with the tiling of the keel i have got a lot of superglue on top of the tiles does anybody know how to clean this up i have tried wet and dry sandpaper but this seems to disintergrate the tiles which i have to replace PLEASE help me out im at a complete loss at what to do beginning to regret taking the copper option THANKS ALOT EVERYBODY
#2 Posted : 06 November 2011 15:19:06
Sorry to say this but superglue is nigh on imposible to remove after its set, try using 1 of the glues recomended by the other victory builders who are doing the copper tiling
willie
#3 Posted : 06 November 2011 16:30:32
why dont you put masking tape on the face of the tiles anny type of glue goes on it will be removed when the tape removed and you can buy tubes super glue remover BigGrinP.S. try E-BAY there's plenty to chouse from
Deepseacodmaster
#4 Posted : 07 November 2011 11:09:43
I used the recomended Bostic solvent free glue
Any excess squashed up onto a tile I removed with the tip of my craft knife when it was drying after about 15 mins.
My main problem is seperating the tiles before I stick them on.
I have tried craft knife with magnifying glass, rubber gloves and rubber thimbles for money counting.
Any help with this would be appreciated.
First Build HMS Victory and HMS Endeavour
Also Krick steam boat "Victoria"
Cheers
Ivan (Ordinary Seaman)
http://www.old-glossop.com
#5 Posted : 07 November 2011 22:38:31
Glue issue.
Really recommend not using supper glue it present so many issues. Neat PVA is working tremendously for me very easy to remove. I suggest lifting the tiles and sanding the glue smooth then start again.
Separating Tiles that stick together.
if you pinch one end of the tiles then rub your thumb and finger on the over end across the width of the tiles they should fan out.
BigGrin
willz
#6 Posted : 07 November 2011 23:09:35
Deepseacodmaster
#7 Posted : 09 November 2011 10:04:58
BigGrin
Thanks Jason
Using your method I have seperated about 80% of the tiles I had not been able to get apart.
I was trying to nip them and pull them length way.
Ivan
Cheers
#8 Posted : 09 November 2011 22:31:23
Looks like a good product, might try that on my fingers. Flapper LOL
This page was generated in 0.117 seconds.
