 Rank: Pro Groups: Registered
Hi Willz Great build mate ,I really admire your handy work with the dremel . Can you tell me What bit you are using in your dremel in the photo . Cheers mald
Hi Willz! Finding space to work is a problem for a lot of model builders! I'm in the same boat, I need a larger shed but it will have to wait till spring now, as my computer desk is not really the ideal place to work now that the ship is getting bigger. Except in the winter when I don't want to shiver me timbers outside in a cold shed. I'm pleased to see the victory's shape is good and the ply looks to have cut well for you. I think you will be glad to get back to working on the hull when you can find some space.
Maldbuild wrote:Hi Willz Great build mate ,I really admire your handy work with the dremel . Can you tell me What bit you are using in your dremel in the photo . Cheers mald Hi maldbuild the bits I`m using in the dremel are these Http://www.ebay.co.uk/it...amp;hash=item5d2f21e320
Very cheap and they do the job Willz
And if you mean the one in the unimat SL its a circular saw for a dremel, just improvised and made a make shift table Willz willz attached the following image(s):
Willz you are a marvel, I take my hat off to you MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
thank you all for your kind words, in the mean time here are a few more bits ready to fit to the launch. Willz willz attached the following image(s):
willz wrote:Maldbuild wrote:Hi Willz Great build mate ,I really admire your handy work with the dremel . Can you tell me What bit you are using in your dremel in the photo . Cheers mald Hi maldbuild the bits I`m using in the dremel are these Http://www.ebay.co.uk/it...amp;hash=item5d2f21e320
Very cheap and they do the job Willz Thanks Willz Keep up the good work Mate
the launch W.I.P. bit of a pain cutting out the holes for the oars Willz willz attached the following image(s):
Great job Willz MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Nice clean lines, a pleasure to look at. TIS
A cracking good job there... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Impresive launch there Steve..
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
Looking good. Keep the pictures comming.
Happy building
Athol
Thanks for the comments lads, appreciated Willz
Hi Willz, Your build is Absolutely spot on your planking is something else well done mate. Regards tf64 Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Fantastic build mate. What a precision, can't wait to see more update :)
slow going but here`s a bit more Willz willz attached the following image(s):
Great clean and tidy lines there Willz. Keep up the good work and looking forward to seeing your progress. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 14/12/2010 Posts: 142 Points: 425 Location: Grantham
That is nothing short of awesome work mate....outstanding
