Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
I thought it was about time That I updated my build diary, I apologise for not doing so sooner but I became so wrapped up in my modelling that time just flew by and I didn't even think about taking any pictures. I will make more effort to do so in future. As can see, I am going for the Victory painted version, points I realise are: 1. I know that the yellow ocre does not follow the lines of the wales as I have painted her so far ( I am hoping that there will be some guidance on the painting of the hull later) 2. The black continues above the upper wale, but I will not touch that until I have finished cutting the gun ports on the poop deck, plus the gunwales. 3. I will paint the lower hull with the copper paint once I have some indication as to how far below the lower wale it is to the water line? That's enough waffle, so here are the pic's. Please comment, whether good or bad. TIS   [  IMG]http://i187.photobucket.com/albums/x135/TIS_05/SN850328.jpg[/IMG]    Next phase is to start on the main deck, finished trimming the rib frames last night.
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Hi Tiswaz.
Nice looking build. I do see however that you have drilled the rope holes in the upper row of gun ports, the magazine though only said the lower to rows.
Hope this is not going to be a problem for you.
Foz
Looks like you've been very busy indeed, the rope holes that shouldn't be are going to need to be filled. Pardon the pun but your likely to come unstuck having done that amount of painting and considering that the gallery is nowhere near complete, such as the gallery glazing and trims need to be put in place before any painting is done, you might now have bonding problems.
Thanks Foz, Tomick for pointing that out  , filled and sorted  . I realise the gallery is a long way from completion, so have just done the french blue as a base coat because of the glazing and mouldings that are to follow. It would have been difficult I think to apply the paint after they have been fitted, as for adhesion, a light rub with the old emery board will give it enough of a key.
Looking real Good Tis...what paints did you use on your build mate... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi Tiz, Very nice build, keep up the good work MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
jonny7england wrote:Looking real Good Tis...what paints did you use on your build mate... Hi Johny, I am using the Victory paints purchased from CMB (acryllics,washes for the upper gun deck, then one coat clear varnish). Will do the 1/4 deck with two washes wood (walnut) brown, then varnish after rub down. On the hull, two wahes yellow ochre and the black is from the pot. Will fine sand all before the final coats are applied.
MWG wrote:Hi Tiz, Very nice build, keep up the good work Thanks MW, am enjoying it immensley, even if I have had one or two frustrations!!! TIS
Hi Tiz,I have said it before and I will say it again, MODELLING IS A JOURNEY NOT A DESTINATION  You have done very well,and eventually you will finish your build to a very high standard MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Tis
Shes really coming along nicely now and will be a real credit to you when finished.
Foz
Thankyou for the compliments fellas. Have just completed cutting the gun ports today and lining the bulwarks, will post pic's when completed. I am more than happy with the way she is comeing along. TIS
Have fallen even further behind now, have not been able to work on her since end of June. I was put on some BP tablets and about 7/10 days later the skin on both my hands started to blister and peel off. Stopped taking them, saw my Dr who put me on some different ones and low and behold they brought me out in a rash all over my body...ArgHHHHH! After several visits to the surgery and trying out different steroid creams and ointments, I was referred to the Dermatology clinic at the local hospital only to be told that the appointment couldn't be before 9/11??? (this was three weeks ago), too long, so went private in the end. saw the Dermatologist within 5-Days, got a different lot of treatment and thank goodness, it is now clearing up. Will give it another week before I commence my build and hopefully will post some pics. Have been following all the prominent builds with interest and can't wait to restart. TIS
Absolutely brilliant Tis...Love it mate!!!
nice one tiss,good luck with the pills and cream,glad your sorted. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Sorry you experienced such a bad reaction to the drugs, but glad you are getting better Tis MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
Sorry to hear about your reaction to common medication. Glad you have resolved the issues and are on the mend.
Happy building
Athol
Take it easy mate vic will wait for you. looks real good by the way “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Sorry your having a bad time of it at the moment, but falling behind may give you the chance to read up on any mistakes mishaps that might happen thus saving you a few headaches in the future.So every cloud has a silver lining as they say regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (8)
