Rope coils! Options
jeff averre
#1 Posted : 24 October 2011 23:07:16
I have been trying to get some nice neat rope coils with the fine cord used for rigging the cannon etc.
Is there a method, technique or special tool to make these coils up, I just seem to end up with a sticky mess most of the time and as I need about 60 for my x-section build, if it's too dificult to get them right I'll just make irregular 'piles' of rope.
Please tell me there is an 'easy' way to do it!! Confused Mellow
Jeff
cal
#2 Posted : 24 October 2011 23:13:03
have u tried masking tape coil the rope on to it then water down some pva & paint it onto the top of it
Wilfy the Sea Dog
#3 Posted : 25 October 2011 00:12:22
I use double sided sticky tape. Coil onto the tape brush with watered down pva, then use a scapel blade or razor blade to carefully lift it off of the tape.
Can be difficult to get the coils but find a decent fine pair of angled tweezers does the trick, think they are 7A.
Hope that helps.
Wilfy
jeff averre
#4 Posted : 25 October 2011 09:18:15
Thank's chap's,
I've tried sticky tape & PVA but but they usually end up unraveling when I pull them off, must admit I hav'nt tried the double sided stuff and like you say, with care and a scalpel it should be a lot easier.Cool
Jeff
ajbird74
#5 Posted : 25 October 2011 20:28:00
Hi
I'm no good at posting pics or graphics but I have seen some place 2 small bits of plastic card (most materials could be utilised) used. As memory recalls you place 1 part of the plastic card over a central pin (read that as fine panel pin in a bit of wood). you then put the 2nd bit of plastic card on top. Net result 2 bits of card on a central pin.
What you then do is secure your cord between the 2 bits if card. As you wind your coil is kept in place by the upper piece of card.
Really hope that makes some sort of sense as I have used this am it really does work very well.
Kind regards
#6 Posted : 25 October 2011 21:39:32
Sounds good TonyBigGrin
#7 Posted : 25 October 2011 23:11:31
Hi guys,
The masking tape method is one of the easiest to get your head around, Just remember once coils are wound on the tape press lightly on it to make it stick more to the tape, then watered down pva over it, dab xs glue up with kitchen roll WAIT for it to dry, the use a razor blade slide under the coil. if you are gentle all is well. When sticking them down to the deck be careful not to add too much glue as it disolves the glue on the coil resulting in it becoming loose. I use this method all the time. I could make around 25 in 5 minutes. just wait for them to dry!!!!BigGrin BigGrin BigGrin BigGrin Cool
Chris..
godey
#8 Posted : 26 October 2011 14:44:24
Rank: Beginner Level 3
just a thought chaps wouldnt it be even easier to glue the coiled rope on the masking tape then trim the masking tape leaving the coil on the masking tape underneath so it cannot be seen? might be easier to glue the coils to the deck as well if that makes sense
cal
#9 Posted : 26 October 2011 21:21:39
i like that idea how many coils on the victory is there apart from the launch
#10 Posted : 26 October 2011 21:56:55
Possible problem with that method is the effect of time on the tape. the tape may warp over time. Once you have washed with watered down PVA it should be fairly robust. best method is definitely the masking tape method. its very easy and adaptable if you want to fashion the rope in a different configuration, lying over a bucket, dead body etc.
jeff averre
#11 Posted : 26 October 2011 22:07:45
Excelent ideas lads,BigGrin I'll get stuck in as soon as I can and post some 'pics',LOL
Thanks everybody,
Jeff
Wilfy the Sea Dog
#12 Posted : 26 October 2011 22:09:37
I can make 5 in 25 minutes & thought that was good going!!! Blushing BigGrin
godey
#13 Posted : 26 October 2011 22:33:39
I dont know what the wife has slipped into my tea but another ideaBlink getting back to Jeffs original post about neat coils how about getting a thin piece of brass tubing or maybe a cotten bud stalk and cutting a slot in the end get the end of the rope in the slot put some watered down pva on a brush and twist the tube on a flat surface with one hand and painting the coil with the other as its turned leave it on the tube until its dry .using cotton bud stems u can make as many as u like at one time .I think I had better lay down for a while.
#14 Posted : 26 October 2011 22:38:18
not ded sure i follow that do you mean coil down the tube?Confused
godey
#15 Posted : 26 October 2011 22:56:29
Hi jase what I thought was put the cord in the slot put the slotted end on a tile or something and turn with the paintbrush on the top. the cord should form a coil extending outwards,the more turns the bigger the coil on the surface of the tile with the paintbrush keeping the coils in place and gluing at the same time .the slot in the tube only needs to be deep enough to hold the end of the cord .I have just seen willies post same sort of idea but using a flat surface the coils can be made as big or small as needed.
#16 Posted : 27 October 2011 22:01:05
Right i have got ya now Mellow
This page was generated in 0.176 seconds.
