 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,188 Points: 15,713 Location: ipswich
STAGE 21:
Front cross member.
Pic 1: Retrieve the front chassis assembly and locate the stabilizer bar 21D. Fit it in place as shown and fix each end to the drop links 15F and 17F using 1 x AM screw in each end.
Pic 2: Detail of the left side.
Pic 3: Detail of the right side.
Pic 4: Fit the 2 x securing brackets 21C and fix with 2 x AM screws in each.
Pic 5: Fit the front cross member 21A as shown and fix using 2 x BM screws.
Pic 6: Fit the front panel 21B and fix with 3 x IM screws.
Pic 7: Store the assemble safely.
STAGE 22:
Chassis centre.
Pic 1: Fit the fuel line 22C to the filter 22B.
Pic 2: Fit the filter to the front of the main chassis 22A as shown and fix with 1 x IM screw.
Pic 3: Fit the front chassis assembly to the main chassis 22A as shown and fix with 2 x BM screws on each side.
Pic 4: Close up of the left side fixings.
Pic 5: Close up of the right side fixings.
Pic 6: Run the two brake lines 20E and 20F along the transmission tunnel as shown.
Pic 7: Fix the lines in place with pieces of tape 22D.
Store the assembly safely for now.roymattblack attached the following image(s):
STAGE 23:
Chassis reinforcement.
Pic 1: Fit the chassis reinforcing rails 23A and 23B as shown. They will only fit one way.
Pic 2: From the other side, fix with 3 x AP screws in each.
Pic 3: Fit the battery wire 23D to the pin underneath the starter motor 7G.
Pic 4: Retrieve the chassis assembly and fit the engine in place between the front side frames as shown.
Pic 5: From underneath, fix the right side of the engine to the chassis with 1 x BM screw.
Pic 6: From underneath, fix the left side of the engine to the chassis with 1 x BM screw.
Pic 7: Fit the transmission support 23C in place and fix with 4 x AM screws.
Pic 8: Secure the gearbox casing using 2 x BM screws.
Pic 9: Connect the end of the fuel line 22C (highlighted in white for clarity) to the pin on the end of the injector rail.
Pic 10: Connect the end of the duct 9O (highlighted in white for clarity) to the pin on the side of the steering pump 14P.
Store the model safely.roymattblack attached the following image(s):
STAGE 24:
Chassis rear reinforcement.
Pic 1: Fit the rear chassis panel 24A to the main chassis 22A as shown. The part needs to be fitted from underneath.
Pic 2: From above, fix with 4 x IP screws.
STAGE 25:
Rear left wheel arch.
Pic 1: Fit the inner arch 25A to the main floor as shown and fix with 2 x BM screws.
Pic 2: Fit the outer arch 25B in place and fix with 2 x IP screws.
STAGE 26:
Rear right wheel arch.
Pic 1: Fit the inner arch 26A to the main floor as shown and fix with 2 x BM screws.
Pic 2: Fit the outer arch 26B in place and fix with 2 x IP screws.
