Megazord Official Build - Issues 97 - 107 Options
#1 Posted : 15 December 2025 10:47:37
STAGE 97:
Dinozord cannons 1.
Pic 1: Fit the connecting piece 97.3 inside the cannon half 97.2 as shown and fix with 2 x PWM screws.
Pic 2: Make two sets the same.
Pic 3: Fit the connecting piece 97.4 inside the cannon half 97.1 as shown and fix with 2 x PWM screws.
Pic 4: Make two sets the same.
Pic 5: Store the parts safely for now.
#2 Posted : 15 December 2025 13:24:15
STAGE 98:
Dinozord cannons 2.
Pic 1: Peel the backing paper off and fit the mount bushings 2 x 98.6 to the two cannon mounts 2 x 98.3.
Pic 2: Fit the parts together as shown.
Pic 3: Retrieve one of the gun parts 97.2 from the previous stage and fit the cannon mount, fixing it with 1 x PWM screw.
Pic 4: Fit the other gun half 97.2 to the cannon mount and fix with 1 x PWM screw.
Pic 5: Press-fit the other two gun halves 97.1 onto the assembly.
Pic 6: Fit the cannons into the lower half of the Dinozord tail 98.1
Pic 7: Fit the top of the tail 98.2 and fix with 2 x PB screws from above and below.
Pic 8: Fit the trim panel 98.4 into the tail part 98.1.
Pic 9: Fit the tail trim 98.5 into the tail part 98.2.
Store the assembly safely.
#3 Posted : 16 December 2025 10:38:23
STAGE 99:
Dinozord body 3.
Due to a missing stage 77 this part cannot be done at this time.
It will be completed when the missing parts arrive.
#4 Posted : 16 December 2025 10:39:28
STAGE 100:
Tyrannosaurus tail 1.
Pic 1: Press-fit the tail parts 100.6 and 100.7 together, trapping the point 100.14 in the end.
Pic 2: Fit the lower tail part 100.9 to the assembly as shown.
Pic 3: Fit the upper tail part 100.8 and fix with 1 x PB screw through the central hole.
Pic 4: Fit the lower tail part 100.1 to the assembly as shown.
Pic 5: Fit the upper tail part 100.2 and fix with 1 x PB screw through the central hole.
Pic 6: Fit the lower tail part 100.4 to the assembly as shown.
Pic 7: Fit the upper tail part 100.3 and fix with 1 x PB screw through the central hole.
Pic 8: Press-fit the trim pieces 100.10 and 100.12 into the tail.
Pic 9: Press-fit the trim pieces 100.11 and 100.13 into the other side of the tail.
#5 Posted : 16 December 2025 13:22:50
STAGE 101:
Tyrannosaurus tail 2.
Pic 1: Retrieve the tail assembly from stage 100 and fit the lower panel 101.2 as shown.
Pic 2: Fit the upper panel 101.1 in place and fix with 1 x PB screw through the centre hole.
Pic 3: Fit the trim panels 101.3, 101.5 and 101.7 to the left side of the tail.
Pic 4: Fit the trim panels 101.4, 101.6 and 101.8 to the right side of the tail.
#6 Posted : 17 December 2025 10:35:56
STAGE 102:
Tyrannosaurus tail 3.
Pic 1: Retrieve the main body assembly and locate the tail panel 102.2.
Fit the panel to the body connector 58.3 as indicated.
Fix with 1 x PB screw.
Pic 2: Fit the connecting block 102.3 as shown.
Pic 3: Fit the tail assembly from stage 101 over the lower post on the panel 102.2.
Pic 4: Fit the top tail panel 102.1 and fix with 2 x PB screws.
Pic 5: Press-fit the trim panel 102.4 in place.
Pic 6: On the other side, press-fit the trim panel 102.5 in place.
Store the model safely.
#7 Posted : 17 December 2025 10:49:16
STAGE 103:
Tyrannosaurus left leg 1.
Pic 1: Fit the hexagonal end of the spindle 103.5 into the locating hole in the foot connector 103.3.
Pic 2: Fit the inner knee joint 103.1 into the leg panel 103.2 as shown.
Pic 3: Fit the kneecap 103.4 in place as shown.
Pic 4: Store the parts safely for now.
This page was generated in 0.173 seconds.
