ET pack 19 Issues 99 - 104 Options
#1 Posted : 16 December 2025 21:12:35
Issue 99
Picture 1 shows the contents of this issue and the previous part from the last issue.
As before when we glued the bottom body part to both the feet, I used some super glue with a brush adapter. This is easier to apply the glue along the seams for this process.
Patience is the key to piecing the parts together, bonding just a small section at a time, making sure that the area is dry before moving onto another small section. I started with the centre back area as this seemed the logical place to start, picture 2.
Gluing the whole two pieces took me around 40 minutes. When the body parts have been glued together, take the time to go around the bonding seam lines looking for any small gaps. I used a small toothpick to apply glue to these areas, pictures 3, 4 and 5.
Picture 6 and 7 shows the complete assembly for this issue.
This page was generated in 0.125 seconds.
