Toyota Supra F+F Issues 21 - 26 Options
#1 Posted : 14 December 2025 12:44:00
STAGE 21:
Front cross member.
Pic 1: Retrieve the front chassis assembly and locate the stabilizer bar 21D.
Fit it in place as shown and fix each end to the drop links 15F and 17F using 1 x AM screw in each end.
Pic 2: Detail of the left side.
Pic 3: Detail of the right side.
Pic 4: Fit the 2 x securing brackets 21C and fix with 2 x AM screws in each.
Pic 5: Fit the front cross member 21A as shown and fix using 2 x BM screws.
Pic 6: Fit the front panel 21B and fix with 3 x IM screws.
Pic 7: Store the assemble safely.
#2 Posted : 15 December 2025 10:28:35
STAGE 22:
Chassis centre.
Pic 1: Fit the fuel line 22C to the filter 22B.
Pic 2: Fit the filter to the front of the main chassis 22A as shown and fix with 1 x IM screw.
Pic 3: Fit the front chassis assembly to the main chassis 22A as shown and fix with 2 x BM screws on each side.
Pic 4: Close up of the left side fixings.
Pic 5: Close up of the right side fixings.
Pic 6: Run the two brake lines 20E and 20F along the transmission tunnel as shown.
Pic 7: Fix the lines in place with pieces of tape 22D.
#3 Posted : 16 December 2025 10:15:52
STAGE 23:
Chassis reinforcement.
Pic 1: Fit the chassis reinforcing rails 23A and 23B as shown.
They will only fit one way.
Pic 2: From the other side, fix with 3 x AP screws in each.
Pic 3: Fit the battery wire 23D to the pin underneath the starter motor 7G.
Pic 4: Retrieve the chassis assembly and fit the engine in place between the front side frames as shown.
Pic 5: From underneath, fix the right side of the engine to the chassis with 1 x BM screw.
Pic 6: From underneath, fix the left side of the engine to the chassis with 1 x BM screw.
Pic 7: Fit the transmission support 23C in place and fix with 4 x AM screws.
Pic 8: Secure the gearbox casing using 2 x BM screws.
Pic 9: Connect the end of the fuel line 22C (highlighted in white for clarity) to the pin on the end of the injector rail.
Pic 10: Connect the end of the duct 9O (highlighted in white for clarity) to the pin on the side of the steering pump 14P.
Store the model safely.
#4 Posted : 16 December 2025 11:56:57
STAGE 24:
Chassis rear reinforcement.
Pic 1: Fit the rear chassis panel 24A to the main chassis 22A as shown.
The part needs to be fitted from underneath.
Pic 2: From above, fix with 4 x IP screws.
This page was generated in 0.166 seconds.
