Red Bull RB19 Official build. Stages 33 - 38 Options
#1 Posted : 12 December 2025 12:39:23
STAGE 33:
Front bodywork 3.
Pic 1: Locate the left air intake parts 33A and 33B.
33B will fit on top of 33A.
Pic 2: Shows the parts assembled.
Pic 3: Retrieve the front body to fit the intake.
Pic 4: Fit the intake 33A/B in place and fix from the inside with 2 x ‘A’ screws.
Pic 5: Turn the body 31A over and locate the steering plate 33C.
Pic 6: Fit the steering plate 33C into the body 31A as shown.
Pic 7: Retrieve the front steering/suspension assembly.
Pic 8: Fit the upper body in place over the suspension assembly, with the body located under the upper suspension arms as circled.
Pic 9: Turn the assembly over and fix the parts with 4 x ‘A’ screws.
Store the assembly safely.
#2 Posted : 13 December 2025 12:12:46
STAGE 34:
Front bodywork 4.
Pic 1: Fit the steering shaft 34D through the lower frame 34B as shown.
Pic 2: Fix the fork 34E to the end of the shaft 34D with 1 x ‘O’ screw.
Pic 3: Fit the lower frame 34B to the upper frame 34A and fix with 2 x ‘G’ screws.
NOTE: The printed instructions incorrectly show the fixing holes at the front edge of the upper frame.
Pic 4: A different view of the assembly.
Pic 5: Turn the upper body 31A over and fit the screen 34C in place.
Pic 6: Fit the upper frame assembly 34A/B to the upper body 31A and fix with 2 x ‘A’ screws where shown.
Pic 7: Fix the parts with two more ‘A’ screws.
Pic 8: Fit the steering column parts 34E and 21B together and secure with 1 x ‘M’ screw.
Pic 9: Fit the compartment support 32C saved from stage 32 in place where shown and fix with 2 x ‘A’ screws.
Pic 10: Store the assembly and unused part safely for now.
#3 Posted : 14 December 2025 15:33:35
STAGE 35:
Steering wheel.
Pic 1: Press-fit the screen 35C into the steering wheel 35A.
Pic 2: Locate the other steering wheel parts 35B and 35E.
Pic 3: Fit the parts as shown to the back of the steering wheel 35A.
35B fits first, then 35E.
Pic 4: Fit the front panel 35D to the upper body as shown.
Pic 5: Fix from underneath with 2 x ‘P’ screws.
Be patient as this is quite fiddly.
Pic 6: Store the assembly and unused parts safely.
#4 Posted : 15 December 2025 10:53:22
STAGE 36:
Left structural panel.
Pic 1: Locate the panel parts 36A and 36B.
36B will fit over 36A where shown.
Pic 2: Press-fit the parts together.
They will only fit one way.
#5 Posted : 16 December 2025 10:35:06
STAGE 37:
Left radiator.
Pic 1: Locate the radiator parts 37A and 37B.
Pic 2: Fit the parts together as shown.
Fix using 2 x ‘A’ screws.
#6 Posted : 16 December 2025 13:25:30
STAGE 38:
Left radiator 2.
Pic 1: Retrieve the radiator assembly from the previous stage and locate the cover panel 38B.
It will fit where indicated.
Pic 3: Fit the structural panel 38A over the radiator assembly.
It will only fit one way.
Fix with 2 x ‘A’ screws.
This page was generated in 0.329 seconds.
