Issue 21
The Upper Parts of the Legs Place (21B), right mounting cover and place it inside the thigh structure, picture 2. Secure it in place using 3 x GM screws, picture 3.
Do the same with the left cover, picture 4.
Insert the support blocks (21C) to both sides by push fitting them in place, as shown in pictures 5, 6 and 7.
Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 22
Right Shoe Heel Place the horn of the right shoe heel (22C) and place it into the hole at the front of the sculpted skull on the heel (22B), picture 2. Secure it in place using an EP screw, picture 3.
Picture 4 shows the assembly complete.
Issue 23
Toe of the Right Shoe Place the left horn (23B) and right horn (23C) and place them on the holes in the top of the Toe (23A), picture 2. Turn the assembly over and secure them in place using 2 x EP screws, picture 3.
Place the toe assembly on the right shoe from issue 22, picture 4. Turn the assembly over and secure the toe in place using 2 x FB screws, picture 5.
Issue 23
The Right Ankle Insert the pointed part of the locking bolt (24C) into the base of the ankle joint (24A), picture 2. Add the spring (24D) as shown in picture 3.
Fit the ankle locking plate (24B) onto the base on the ankle and secure with 2 x BM screws, picture 4.
Finally, attach the assembly to the inside of the shoe assembly from the previous issue and secure it in place using 2 x EM screws, picture 5.
Picture 6 shows the assembly complete for this issue.
Issue 25
The Right Shoe Sole Retrieve the assembled left shoe and turn it over and place the shoe sole (25A) on the bottom securing it using 2 x FM screws, picture 2.
I will place the four retention discs on each side of the ankle joint in the when it is needed.
Picture 3 shows the assembly complete for this issue.
Issue 26
The Strap of the Right Shoe Retrieve the left shoe heel and place the strap (26D) into the back. Place the mounting plate (26C) over the two holes and secure in place using 2 x EP screws, picture 2.
Place the skull ornaments (26A) on each side of the strap and secure in place using 2 x GP screws, pictures 3 and 4.
Retrieve the shoe assembly from issue 25 and place the strap assembly over the shoe as you did with the left side assembly. To secure the strap in place over the shoe, take the central attachment loop (26G) inside the central tab of the strap. Press the loop firmly into the two holes on the top centre of the show, picture 5.
Take the two other side taps and place the side loops into the straps as you did with the central tab. Push fit the loops in place on each side of the shoe as shown in pictures 6.
Picture 7 shows the assembly complete for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
