 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,188 Points: 15,713 Location: ipswich
STAGE 105:
Rear left brake and wheel fitting.
Pic 1: Fit the caliper part 105E to the left rear hub and fix with 2 x AP screws.
Pic 2: Locate the disc parts 105F and 105G. These parts will fit together as indicated.
Pic 3: Fit the parts together and fix with 2 x ZP screws.
Pic 4: Fit the disc to the hub as shown.
Pic 5: Press-fit the caliper front 105D in place.
Pic 6: Retrieve the wheel from stage 104 and the bolts 105B.
Pic 7: You will find it far easier to fit the centre bolts while the wheel is off the car, as opposed to the printed instructions which suggest fitting the wheel first.
Pic 8: Fit the wheel to the car as shown. It will only fit properly one way as there is a keyway on the disc and the rear of the wheel which must be in line. Fit the centre washer 105C and then fix the wheel with 1 x DM screw.
Pic 9: Press-fit the centre cap 105A in place.
Store the model safely for now.roymattblack attached the following image(s):
STAGE 106A:
Rear and front right wheels.
Pic 1: Locate the tyre and inner wheel 106A and 106C.
Pic 2: Fit the rim inside the tyre as shown.
Pic 3: Fit the rim 106D in place making sure the screw tabs all line up.
Pic 4: Fit the outer rim 106B in place as shown.
Pic 5: Fix the parts together from the inside with 3 x ABM screws.
Pic 6: Retrieve the brake caliper from stage 14 and carefully separate the parts.
Pic 7: Fit the caliper part 14B to the left front hub and fix with 2 x AP screws.
STAGE 106B:
Pic 8: Retrieve the disc parts 14C/D from stage 14 and fit to the hub as shown.
Pic 9: Press-fit the caliper front 14A in place.
Pic 10: Retrieve the wheel from stage 16 and the bolts 16C.
Pic 11: You will find it far easier to fit the centre bolts while the wheel is off the car, as opposed to the printed instructions which suggest fitting the wheel first.
Pic 12: Fit the wheel to the car as shown. It will only fit properly one way as there is a keyway on the disc and the rear of the wheel which must be in line. Fit the centre washer 106E and then fix the wheel with 1 x DM screw.
Pic 13: Press-fit the centre cap 16B in place.
Pic 14: Store the model and wheel safely for now.
STAGE 107:
Rear right wheel.
Pic 1: Fit the caliper part 107 to the rear hub as shown and fix with 2 x AP screws.
Pic 2: Fit the disc parts 107G and 107F together and fix with 2 x ZP screws.
Pic 3: Fit the assembled disc in place on the rear hub.
Pic 4: Press-fit the caliper front 107D in place.
Pic 5: Retrieve the wheel assembly from the previous stage and the bolts 107B.
Pic 6: You will find it far easier to fit the centre bolts while the wheel is off the car, as opposed to the printed instructions which suggest fitting the wheel first.
Pic 7: Fit the wheel to the car as shown. It will only fit properly one way as there is a keyway on the disc and the rear of the wheel which must be in line. Fit the centre washer 107C and then fix the wheel with 1 x DM screw.
Pic 8: Press-fit the centre cap 107A in place.
Pic 9: Store the model safely for now.roymattblack attached the following image(s):
STAGE 108:
Windscreen wipers.
Pic 1: Open the bonnet (hood) of the car.
Pic 2: From the windscreen side, fit the wiper 108B under the rear of the bonnet, to locate in the hole in the bulkhead as indicated.
Pic 3: Repeat with the wiper 108A.
Pic 4: If you did not fit the screws at the front of the inner wings when mounting the body, fix now using 1 x BM screw in each side.
Pic 5: The other side.
Pic 6: Fit the rear wiper 108C in centre of the rear screen.
Store the model safely.roymattblack attached the following image(s):
STAGE 109:
Rear side windows.
Pic 1: Apply pieces of the double sided tape strips 2 x 109D and 1 x 109C to the car body window opening where shown.
Pic 2: Peel the backing from the tape strips and press the correct rear window in place as shown.
Pic 3: Apply pieces of the double sided tape strips 2 x 109D and 1 x 109C to the car body window opening where shown.
Pic 4: Peel the backing from the tape strips and press the correct rear window in place as shown.
STAGE 110:
Mats and trim.
Pic 1: Peel the backing from the double sided adhesive sheets 110D and apply them to the rear of the floor mats 110A and 110B.
Pic 2: Peel the backing from the tape and apply the mat in the relevant place as shown.
Pic 3: Peel the backing from the tape and apply the mat in the relevant place as shown.
Pic 4: Retrieve the inner front wing trim strips 84B and 86B saved from stages 84 and 86. They are marked ‘L’ and ‘R’. Apply pieces of tape 110E to the back of each strip as shown.
Pic 5: Peel the backing from the strips and press them in place on the inside upper edge of the front wings as shown.
Pic 6: If you have not already done so, fit the piston and sleeve of the boot struts together on each side.
Pic 7: You can use the 4 x support blocks 110C under the sides of the model to keep the weight off the wheels and suspension.
Pics 8 - 11: Congratulations – You have completed your Nissan GTR model.
