Issue 27
The Abdominal Structure
Picture 1 shows the contents of this issue. Retrieve the chest assembly from the previous issue, Arrange the left abdominal structure as shown in pictures 2 and 3.
Prepare two type H bolts by placing a serrated washer on them, picture 4.
Turn the assembly over and place a M3 nut into the recess as shown in picture 5. Holding it into position, turn the assembly back over and insert the bolt into the nut, tightening it using the allen key supplied with this kit, picture 6. Place the other bolt and nut as shown in picture 7.
Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 28
Picture 1 shows the contents of this issue. Before assembling the right abdominal structure, place an M3 nut into the recess at the back of the part, as shown in picture 2. DO NOT proceed with the assembly without placing this nut first.
Retrieve the chest assembly from the previous issue, Arrange the right abdominal structure as shown in picture 3.
Prepare the type H bolts by placing a serrated washer on them, picture 4.
Turn the assembly over and place a M3 nut into the recess as shown in picture 5. Holding it into position, turn the assembly back over and insert the bolt into the nut, tightening it using the allen key supplied with this kit, picture 6. Place the other bolts and nut as shown in picture 7.
Finally, place the last H bolt and nut as shown in picture 8.
Picture 9 shows the completed assembly for this issue.
Issue 29
The Abdominal Details
Picture 1 shows the contents of this issue. Position the left abdominal detail and secure in place using 2 x Type E screws, picture 2.
Do the same on the right-hand side using the right abdominal detail, picture 3.
Issue 30
Picture 1 shows the contents of this issue. Place the left abdominal blue plate into position, securing it in place using 2 x E screws as shown in picture 2.
Finally, attach the inner detail and again securing it with an E type screw, picture 3.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 31
Picture 1 shows the contents of this issue. Place the right abdominal blue plate into position, securing it in place using 2 x E screws as shown in picture 2.
Finally, attach the inner detail and again securing it with 2 x E type screw, picture 3.
Issue 32
The Chest Symbol
Picture 1 shows the contents of this issue. Push the centre chest detailing into position and secure it using 3 x E type screws, picture 2.
Push fit the lower red chest place into position as shown in picture 3.
Picture 4 shows the completed assembly for this issue.
