Red Bull RB19 Official build. Stages 21 - 26 Options
#1 Posted : 11 October 2025 13:28:03
STAGE 21:
Steering column.
Pic 1: Fit the two steering column parts 21A and 21B together as shown and fix them using 1 x ‘M’ screw.
Pic 2: This is to identify the three different brackets.
Pic 3: Retrieve the car nose assembly and fit bracket 21D in place as shown.
It will only fit one way.
Pic 4: Lay the column 21A in place with the double-collar section over the bracket.
Pic 5: Fit bracket 21C over the top, trapping the column in place.
Fix using 2 x ‘A’ screws.
Pic 6: Fit bracket 21E in place at the other end of the steering column as shown and secure with 2 x ‘A’ screws.
Store the assembly safely.
#2 Posted : 12 October 2025 12:00:07
STAGE 22:
Front right suspension.
Pic 1: Fit the suspension arm 22B through the slot in the back plate knuckle 22D as shown.
The red line indicates the correct angle each end of the arm should be.
Do not fit the arm upside-down.
Pic 2: Fit the retaining plate 22C to the end of the arm and fix with 1 x ‘C’ screw.
Pic 3: Fit the double arm 22A through the slot as shown and fix to the other tabs on the retaining plate with 1 x ‘C’ screw.
Pic 4: Fix the retaining plate in place using 2 x ‘A’ screws.
#3 Posted : 13 October 2025 10:33:15
STAGE 23A:
Front right suspension 2.
Pic 1: Locate the hub parts 23E and 23G.
Pic 2: Fit the parts together as shown.
Pic 3: Retrieve the assembly from the previous stage and fit the hub parts in place as shown.
Pic 4: Fix the parts together from the other side with 2 x ‘B’ screws.
#4 Posted : 13 October 2025 10:35:15
STAGE 23B:
Pic 5: Locate the brake disk and outer detail, 23B and 23C.
Pic 6: Fit the hook end of the detail strip into the slot in the disc.
Pic 7: Wrap the strip around the disc and fit the other end into the slot in the disc.
Fold the tab over inside the disc.
Pic 8: Locate the other disc parts 23A and 23C.
23C will go on top of 23A.
Pic 9: Peel the backing paper from the rear of 23C and stick the part in place on the front of 23A.
Pic 10: Press-fit the assembly onto the main disc, 23B.
Pic 11: Store all parts safely for now.
#5 Posted : 14 October 2025 10:43:11
STAGE 24:
Front right suspension 3.
Pic 1: Locate the right upper arm 24B and note than one of the end tabs is longer than the other.
Insert that end into the upper slot on the hub back plate, noting the upward angle of the tab on the other end, indicated by the red line in the pic.
The upper tab should be directly under the screw hole in the silver hub upright.
Pic 2: Fit the tab on the end of the suspension arm 24A under the hole in the top of the silver hub upright.
Make sure you fit the suspension arm the right way round as shown.
Pass a ‘D’ screw through the hole in the silver hub, and through the two arms just fitted.
Tighten the screw to keep everything in place.
Pic 3: Store the assembly safely.
#6 Posted : 15 October 2025 10:51:41
STAGE 25A:
Front right suspension 4.
Pic 1: Retrieve the suspension assembly from the previous stage and press-fit the small air intake 25A into the back plate 22D.
Pic 2: Fit the fairing 25B in place around the suspension arms as shown.
Pic 3: Fix it from the other side with 2 x ‘A’ screws.
Pic 4: Fit the brake plate 23F from stage 23 as shown.
Pic 5: Fit the disc assembly from stage 23 as shown.
Pic 6: Press-fit the hub 25C in place.
NOTE: The part is incorrectly labelled 23C in the printed instructions.
#7 Posted : 15 October 2025 10:54:15
STAGE 25B:
Pic 7: Retrieve the front assembly and fit the new suspension parts in place as shown.
The arms will each only fit in one location.
Pic 8: A different view of the assembly.
Pic 9: A different view of the assembly.
Pic 10: Fix the rear upper arm using 2 x ‘E’ screws.
Pic 11: Fix the lower arms using 1 x ‘A’ and 1 x ‘C’ screw as shown.
Pic 12: Fit the steering rack 25D under the two arms 22B and 4F as shown and fix from above using 2 x ‘N’ screws.
Pic 13: Store the assembly safely for now.
#8 Posted : 16 October 2025 10:21:21
STAGE 26:
Front right suspension 5.
Pic 1: Retrieve the assembly from stage 25 and the inner brake cover 26B.
The highlight areas are where the parts will clip together.
Pic 2: Shows the part in place.
Pic 3: Press-fit the outer cover 26C in place as shown.
Pic 4: Turn the assembly upside down and press-fit the brake caliper 26A in place.
The red highlight circles show where the parts will fit.
Pic 5: Store the assembly safely for now.
