The iconic vehicle from the Tim Burton movie comes to life in an extraordinary build-up model. Reflecting the film’s Art Deco style, the Batmobile defined a new dimension of cool with sleek styling and an arsenal of hi-tech gadgets that made it Batman’s ultimate crime fighting tool.
Tim Burton's live-action films Batman (1989) and Batman Returns (1992) presented a different version of the Batmobile, which reflected those films' Art Deco version of Gotham City. The car was designed by conceptual illustrator Julian Caldow and built by John Evans special effects team at Pinewood Studios in England. The body of the car was sculpted out of foam by Keith Short in collaboration with Eddie Butler and the fiberglass work being done by John Lovell. It was long, low, and sleek, and was built on a Chevrolet Impala chassis. For Batman Returns in 1992, Carl Casper and Tom Oberhaus of Hollywood Productions were contracted to build 3 Batmobiles for principal photography.
Build this incredible model. To sign up right now, go here:
https://www.fanhome.com/...e-series/batmobile-1989
The official build will be here soon.
WATCH THIS SPACE.roymattblack attached the following image(s):
STAGE 1A:
Hood and turbine.
Pic 1: Fit the hood parts 1-1 and 1-2 together and fix with 2 x ‘A’ screws and 1 x ‘C’ screw.
Pic 2: Repeat with the other hood part 1-3.
Pic 3: Shows the parts assembled.
Pic 4: Fit the two pulleys 1-5 and 1-6 inside the turbine housing 1-4 as shown.
Pic 5: Fix from the other side with 2 x ‘B’ screws.
Pic 6: Fit the large pulley 1-7 in the centre of the housing.
Pic 7: Fit one of the bands 1-8 around the pulleys as shown. This band will locate in the lower groove in pulley 1-7.
Pic 8: Fit the other band 1-9 around the pulleys as shown. This band will locate in the upper groove in pulley 1-7.
STAGE 1B:
Pic 9: Fit the turbine parts 1-10 and 1-12 together as shown.
Pic 10: Press-fit the two vanes 1-13 into two of the slots in 1-12 as shown.
Pic 11: Fit the vane 1-14 into the other slot in 1-12.
Pic 12: Fit the turbine blades 1-11 inside the housing. There is a keyway location fitting on the centre spindle and in the pulley 1-7 underneath.
Pic 13: Fit the centre turbine assembly in place making sure the central cone angles up toward the widest part of the surround, and the screw locations are aligned with the holes underneath.
Pic 14: Fix the parts together with 3 x ‘D’ screws from underneath.
Pic 15: Fit the assembly 1-4 inside the upturned hood 1-1 and fix using 3 x ‘A’ screws.
Pic 16: Store the assembly safely for now.roymattblack attached the following image(s):
STAGE 2:
Rear wheel.
Pic 1: Fit the badge 2-2 to the hub 2-3 and fix from inside with 1 x ‘D’ screw.
Pic 2: Fit the inner wheel 2-1 to the outer wheel 2-4 making sure the screw hole locations line up on both parts. Fix together with 4 x ‘D’ screws.
Pic 3: Soak the tyre 2-6 in hot water for around 1 minute. TAKE CARE HERE.
Pic 4: Remove the tyre from the water using tongs and dry the tyre. Place the tyre on a firm surface with the large opening up. Fit the wheel into the tyre with the face of the wheel and the valve detail down. Press firmly to fit the tyre over the wheel.
Pic 5: Fit the outer tyre panel 2-5 in place with the screw holes in alignment. Fix the parts together with 4 x ‘D’ screws.
Do not over tighten these screws as you may drive them through the rubber.
Pic 6: Store the parts safely for now.
