Batmobile Official Build Pack 19 Options
#1 Posted : 15 September 2025 10:36:37
Issue 100
Fitting the Trim and Attaching the Door
Retrieve the door trim from issue 99 and insert it in the left door inside panel (100A), picture 2. Turn the assembly over and secure it in place using 3 x AP screws, picture 3.
Push the door handle (100B) through the oval shape hole, picture 4. Cover the round part of the door handle with the door handle bracket (100D) securing it in place using 2 x AP screws, picture 5.
Turn the assembly back over and attach the door handle head (100C), picture 6 and 7.
Take the door panel assembly and attach it to the left door using 4 x AP screws, picture 8.
Use 4 x EN screws to attach the door hinge (100E) to the body frame, picture 9.
Finally, attach the door to the hinge using 2 x EM screws.
#2 Posted : 15 September 2025 10:38:47
Issue 101
Fitting the Hinges
Fix the two door hinges (101B & 101C) to the door as you did previously, picture 2.
Picture 3 shows the assembly complete for this issue.
#3 Posted : 16 September 2025 10:28:11
Issue 102
Assembling the Door
Attach the right door handle (102B), picture 2.
Secure the inner side piece (98A) using 3 x EM screws as shown in picture 3.
#4 Posted : 17 September 2025 19:57:33
Issue 103
Fitting the Hinge Panel
Secure the left hinge panel (103A) on the rear of the door so it covers part of the door hinges. Secure it in place using 2 x CM screws, picture 2.
#5 Posted : 17 September 2025 20:03:58
Issue 104
Retrieve the door trim from issue 103 and insert it in the left door inside panel (104A), picture 2. Turn the assembly over and secure it in place using 3 x AP screws, picture 3.
Push the door handle (104B) through the oval shape hole and cover the round part of the door handle with the door handle bracket (104D) securing it in place using 2 x AP screws, picture 4.
Turn the assembly back over and attach the door handle head (104C), picture 5 and 6.
Take the door panel assembly and attach it to the left door using 4 x AP screws, picture 7.
Use 4 x EN screws to attach the door hinge (104E) to the body frame, picture 8.
Finally, attach the door to the hinge using 2 x EM screws, picture 9.
Picture 10 shows the completed assembly for this issue.
#6 Posted : 19 September 2025 13:26:07
Issue 105
Picture 1 shows the parts for this issue.
Securing the Cables
Begin by carefully turning the body panel assembly over and remove all the 12 CM screws and separate the two body panels. Note you are given replacement CM screws to reassemble these parts later in the assembly stage, pictures 2 and 3.
Place the left (105B) and right (105D) lenses onto the rear of the body frame securing them in place using 2 x BM screws for each lens, pictures 4 and 5.
Unplug the two rear turn signals marked “E” and “F” and the rear lights marked “I”, picture 6.
Fix both the cable clips (105E) and feed the cables as shown in picture 7.
Assemble the two body panels together again using the new CM screws provided.
Push the four LED bulbs into the back of the two light housings. Use the black tape provided to stick down the cables as shown in picture 8.
Note: I found that the rear red light LED cables was quite taught when it was in the cable clip, so I re-threaded it, bypassing the clip also shown in picture 8 by the red two arrows.
Picture 9 shows the assembly for this issue complete.
#7 Posted : 19 September 2025 13:29:12
Issue 106
Fitting the Windshield
Retrieve the windshield from issue 4 and secure it to the front body panel (106A) using 4 x AM screws, picture 2.
Picture 3 shows it in place.
The last two pictures, I placed the body panels, bonnet and roll bar onto the chassis to see what it looks like.
This page was generated in 0.307 seconds.
