Issue 6
Toe of the Left Shoe Place the left horn (6B) and right horn (6C) and place them on the holes in the top of the Toe (6A), picture 2. Turn the assembly over and secure them in place using 2 x EP screws, picture 3.
Place the toe assembly on the left shoe from issue 5, picture 4. Turn the assembly over and secure the toe in place using 2 x FB screws, picture 5.
Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 7
The Left Ankle Insert the pointed part of the locking bolt (7B) into the base of the ankle joint (7A), pictures 2 and 3. Add the spring (7C) as shown in picture 4.
Fit the ankle locking plate (7D) onto the base on the ankle and secure with 2 x BM screws, picture 5.
Finally, attach the assembly to the inside of the show assembly from the previous issue and secure it in place using 2 x EM screws, picture 6.
Picture 7 shows the assembly complete for this issue.
Issue 8
The Left Shoe Sole Retrieve the assembled left shoe and turn it over and place the shoe sole (8A) on the bottom securing it using 2 x FM screws, picture 2.
Place the four retention discs on each side of the ankle joint as shown in picture 3.
