 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,055 Points: 15,311 Location: ipswich
Those two screws at the bottom of the grille are fun! They took me quite a while too. No matter what screwdriver I tried, none of them seemed to quite fit. Got there in the end though. Looking good. Keep it coming.
Joined: 26/04/2014 Posts: 1,395 Points: 4,094 Location: Essex
Cheers Roy👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 15 here now Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 75. Left side pod. The radiator top mount was a pain. The screw holding the top bracket could of done with being a countersunk screw as the head was stopping The mount going all the way in. Had to overtighten it just enough to get the screw to squash onto the plastic to give me the clearance needed to get the mount in place. Got there in the end! Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 76, left radiator fittings Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 77. Left side pod bodywork Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 78. Left sidepod bodywork. I found when fitting the lower water pipe just before putting on the bodywork to unscrew the ecu from the side. Makes it a lot easier when fitting the pipe to the lower part of the radiator Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 79. Right side turbo started on. For some reason the hanger rod will not reach the connection on the turbo. Not sure what I can do about it at the moment☹️ Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 80. Right turbo and pipes. That's pack 15 done. Now waiting for pack 16 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
As she's looking at the 3/4 mark👍 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,861 Points: 20,900 Location: Northamptonshire, England
That is taking shape very nicely Steve. Mark Regards Markwarren (Mark) Admin
Cheers Mark😘 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looking really good. Great to see another one coming along.
Roy
Pack 16 here now. Stages 81-86 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 81. Right side turbo intake and radiator pipe Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 82. Right side intercooler Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 83. Right side intercooler installed Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Nice work Steve, coming on very nicely. Mark Regards Markwarren (Mark) Admin
Cheers Mark. Stage 84 done. Intercooler duct and ecu Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Keep it coming Steve. Looking really good.
Guest (5)
