Nissan Skyline Official build - Stages 81 - 86 Options
#1 Posted : 24 April 2025 17:38:46
STAGE 81:
Right door.
Pic 1: Fit the inner trim, part 81B to the inside of the trim part 81A.
It will only fit one way.
Pic 2: Retrieve the right door assembly and fit the trim panel as shown.
Secure it using 5 x OP screws.
Pic 3: Press-fit the two door speakers, 81C and 81D into the door panel as shown.
#2 Posted : 25 April 2025 10:58:16
STAGE 82:
Bonnet/Hood.
Pic 1: Retrieve the main body shell assembly and fit the windshield cowling 82A as shown.
Pic 2: Secure the part from underneath using 3 x CP screws.
Pic 3: Retrieve the main bonnet/Hood assembly to fit the hinge parts as shown clearly in the next pictures.
Pic 4: Fit the left hinge bracket 82B to the inside of the bonnet/hood as shown.
The part will only fit one way.
Secure with 2 x AM screws.
Pic 5: Fit the right hinge bracket 82D to the other side of the bonnet/hood as shown.
Pic 6: Fit the other part of the left hinge bracket 82C to part 82B as shown and fix using 1 x AMC screw.
Pic 7: Fit the other part of the right hinge bracket 82E to part 82D as shown and fix using 1 x AMC screw.
#3 Posted : 26 April 2025 12:35:36
STAGE 83:
Front left wing.
Pic 1: Locate the front wing and inner guard, parts 83A and 83B.
Pic 2: Fit the parts together as shown.
They will only fit one way.
Secure with 2 x SM screws.
Pic 3: Press the small GT badge, part 83C in place on the lower rear edge of the wing.
Make sure it is upright.
#4 Posted : 27 April 2025 13:34:35
STAGE 84:
Front body frame.
Pic 1: Retrieve the main body, 61A and locate the left front reinforcing frame, 84A.
Pic 2: Fit the parts together as shown and fix with 2 x AIM screws.
Pic 3: Shows the stage completed.
Keep the unused part.
#5 Posted : 29 April 2025 10:03:02
STAGE 85:
Front right wing.
Pic 1: Locate the front wing and inner guard, parts 85A and 85B.
Pic 3: Press the small GT badge, part 85C in place on the lower rear edge of the wing.
#6 Posted : 02 May 2025 10:46:04
STAGE 86:
Front body frame.
Pic 1: Retrieve the main body, 61A and locate the right front reinforcing frame, 86A.
Store the unused part safely.
This page was generated in 0.251 seconds.
