The Red Bull Racing RB19 is a championship-winning Formula One car designed and constructed by Red Bull Racing and powered by the Honda RBPTH001 power unit which competed in the 2023 Formula One World Championship.
The car was unveiled on 3 February 2023. The RB19 was driven by defending world champion Max Verstappen and Sergio Pérez. The car also marked the return of Honda as a named engine supplier to Red Bull Racing and AlphaTauri, with both teams' engines badged as Honda RBPT.
The RB19 is one of the most dominant cars in the history of the Formula One World Championship, winning 21 out of the 22 races it competed in, thereby outperforming the McLaren MP4/4's previous record of winning 15 out of 16 races that had stood since the 1988 F1 season.
Watch this space for the official build:roymattblack attached the following image(s):
STAGE 1 A:
Front wing.
Pic 1: Locate the nose cone, part 1F and the wing plane 1E. The wing planes can be identified by the parts of text on each.
Pic 2: Fix the parts together as shown using 1 x A screw.
Pic 3: Locate the wing part 1D.
Pic 4: Fix as before using 1 x A screw.
STAGE 1 B:
Pic 5: Locate the wing part 1C.
Pic 6: Fix as before using 1 x A screw making sure the wing clips in place to the wing part next to it, as shown.
Pic 7: Fit the final wing part 1B in the same way as the previous part, 1C. Make sure the wing clips in place to the wing part next to it, as shown.
Pic 8: Assembly so far.
Pic 9: Fit the large front wing part 1A in place as shown and fix using 2 x A screws.
Pic 10: Stage completed.
Store the part safely for now.
STAGE 2:
Front wing.
Pic 1: Retrieve the assembly from stage 1 and the wing end plane, part 2C. The tabs on the wing tips will fit into the slots under the wing end plane.
Pic 2: Press the parts together as shown:
Pic 3: Fit the other wing end plane, part 2B in the same way.
Pic 4: Locate the front wing, part 2A. The centre pin will fit in the hole in the end of the nose cone and the ends of the wing will fit in the slots in the end planes.
Pic 5: Wings assembled.
Pic 6: Fit the lower nose section 2D in place as shown and fix using 2 x A screws.
Pic 7: Stage completed.
