Snoopy's House Official Build Pack 7 Options
#1 Posted : 07 April 2025 21:11:16
Issue 24
Assembling the Freezer Display
Check which way around the freezer base and freezer display goes, picture 2. Glue the ice creams into the base as shown in picture 3. Test fit this part first.
Take off the protective film from both sides of the display window, picture 4. Again, test fit this part first making sure you have the correct orientation before glueing into place, picture 5. Glue the display top on the display window, picture 6.
Take the display base to the ice cream parlour, and check you have the right orientation, picture 7.
Glue the back wall in place making sure the smooth side is facing towards you. Use a drop of instant glue to secure it in the base, picture 8. Now attach the floor, glueing it to the back wall and base, picture 9.
Add the ice cream freezer, using a drop of glue to hold it in place, picture 10.
Finally, add Sally as shown in picture 11.
That complete the assembly from this issue.
#2 Posted : 09 April 2025 10:53:52
Issue 25
Assembling the Ice Cream Parlour Display
Retrieve the ice cream parlour scene from the last issue and place the two side walls in the same way as you have done before, picture 1.
Take the three flag sheets and peel off two of each colour. Carefully, bend the flags in half, sticking the two points together, but leaving a gap at the top to feed through the wire as shown in picture 2.
Place one of the pink flags onto the wire making sure that the side is about halfway along the wire as illustrated in picture 3. With that flag fixed in place, position all the other flags as shown in picture 4.
Before we fix the flags in place, glue the two ice cream cones to the top of the freezer inserting the pins into the holes.
Take the flag assembly and fit the wire into the holes on the side walls, picture 5 and then bend the wire either end as shown in picture 6. Finally, glue Snoopy in place next to Sally.
Picture 7 shows the completed assembly for this issue.
#3 Posted : 11 April 2025 14:39:18
Issue 26 Part 1
Picture 1 shows the parts for this issue
Assembling the Base and Background Parts
Take the grass base and apply PVA glue to the top, picture 2. Place the glue painted grass base in a pot of some kind and sprinkle some of the green flocking over the glued area. Pat the flocking down to give a good adhesion, picture 3. Allow this to dry for 24 hours, picture 4.
Take the back wall, making sure you have it the right way around, and glue in place the two cloud pieces, picture 5. Now take the base, noting its orientation, and the back wall and glue them in place as shown in picture 6 and 7.
That completes part 1 of this assembly.
#4 Posted : 11 April 2025 14:40:57
Issue 26 part 2
Retrieve the four packs of pillow parts, picture 8. Break apart the wadding and stuff it all into the pillow, picture 9. Glue the end using PVA glue and hold it together using a clamp, picture 10. Do the same with the remaining three pillow and set aside to enable the glue to set.
Once the glue is dry, trim off any frayed ends and then place them in the bed scene as illustrated in pictures 11 and 12.
Finally glue the bed onto the base and then glue the flowerpot stand.
Picture 13 shows the completed assembly for this issue.
#5 Posted : 13 April 2025 18:35:54
Issue 27
Assembling the Slope, wall, Tree and Side Walls.
Retrieve the “Brick Wall” scene from the previous issue and add the slope by inserting the two
tabs into the two slots in the back wall, picture 2. DO NOT glue this place just yet. Take the grass and place it on top of the base of the scene, again DO NOT glue in place, picture 3.
Picture 4 shows the tree and wall I painted to make them look a little more realistic. For the tree, I painted a dark brown wash, left to dry before dry brushing a very light brown acrylic paint to highlight the areas and give it a little more depth. For the leaves I used a yellow acrylic paint to highlight some of the green areas.
The wall was painted with a dark brown wash, left to dry, and then dry brushed with a cream paint.
Attach the brick wall to the base, inserting the two tabs on the bottom of the wall into the grass and base, picture 5. I found it easier to push the wall into the grass base first, holding the two parts, pushing them together before glueing the tabs to the base.
Now, glue the outer bottom sides of the grass base to the main base, then glue the slope to the base and add a little glue to the tabs at the back of the back wall.
Glue the tree in place, picture 6.
Picture 7 shows Lucy and Charlie Brown positioned behind the wall. DO NOT glue the figurines in place.
#6 Posted : 15 April 2025 10:33:27
Issue 28
Adding the Trees, Leaves and House
First, take the three leaf sheets and using a sharp craft knife cut out the leaves, picture 2.
Retrieve the “Brick Wall” scene and using a cocktail stick apply a little PVA glue and dab a small amount onto the slope, then add the leaves. This is a timely process but will make all the difference to the scene. Note, I placed a clump of the leaves around the tree base, picture 3.
Glue the tree and house in the slots at the top of the slope as shown in picture 4. I found it easier to place the two parts by removing the side walls.
Place Lucy to the left of the wall and add a drop of instant glue to her elbows placing them in the hollows on the top of the wall. Add Charlie Brown in a similar way and then Linus, picture 5.
Assembling the Box Top
Check which way round the box top goes. You’ll be working on the side with the moulded detail. Take the circuit board and place it into the box top and secure it with two of the screws supplied in this issue, pictures 6 and 7.
This page was generated in 0.455 seconds.
