International Space Station Official Build - Pack 12 Options
#1 Posted : 20 February 2025 20:41:22
Hi All, BigGrin
Here we are back with the ISS, pack 12 / issue 57.
Parts supplied.....Pic 1, you will also need the main model on the stand and the solar panel assemblies from issues 49 and 53.
Lets start with the main model and add the three BASE 12 parts as indicated in Pic 2.
Now take the single sided solar array from issue 49 and place the centre spindel into part 26N as shown in Pic 3. Then add part 26O over the spindle as in Pic 4 and secure the parts using 3 x MS4 screws as in Pic 5.
Next, bring the double sided solar array from issue 53 to the table and place the part 26Y as shown in Pic 6. Keep the double sided array on the table and add the single sided array you were just working on as shown in Pic 7, with the joint close-up shown in Pic 8.
That`s it for this update as shown in Pic 9, but DON`T FORGET the last panel is not securely fixed in place. See you soon for the next update.
(Derek) Admin
#2 Posted : 21 February 2025 21:11:51
Hi All, BigGrin
Here`s the next ISS update #58, where we add trim to the base and fit the fourth double solar array.
Parts supplied.....Pic 1, you will also need the main model (on its stand) and the large solar array from the last update, along with the solar array from issue 56.
We start by adding the 3 x BASE 12 parts supplied onto the main model base, as shown in Pic 2.
Place the spindle end of the solar array from issue 56, into part 26Q as in Pic 3. Then place the part 26P on top, Pic 4. You can now fix the parts together using 3 x MS4 screws, Pic 5. Next fit the spacer 26Z into the main solar array from the last update, Pic 6. Bring the double panel you worked on earlier and place it onto the spar with the other three double panels as shown in Pic 7.
Finally, fit the recent panels to the spar using 3 x MB4L screws as in Pic 8. The whole solar array is now shown in Pic 9. Next update coming ASAP.
(Derek) Admin
#3 Posted : 23 February 2025 12:52:19
Hi All, BigGrin
I`m back again, this time for issue 59. In this update, we add some of the final detail to the main solar array.
Parts supplied.....Pic 1, you will also need the main solar array from the last update.
Start by positioning the parts 26R and 26L together (they only fit one way), as in Pic 2 and fix them together using 2 x AS5 screws as shown in Pic 3.
Now, position the assembly into place on the main array as in Pic 4, then secure it in place using 4 x MS4 screws as in Pic 5.
Finally press the detail part 26C into position as shown in Pic 6. That`s all for this update, Pic 7. Next update coming soon.
(Derek) Admin
#4 Posted : 24 February 2025 19:31:07
Hi All, BigGrin
Back with the ISS as another pack is in the pipeline.
Issue 60
Parts supplied.....Pic 1, you will also need the main model on its base.
Press fit the 3 x BASE 12 parts as shown in Pic 2 and save the remaining part until next time. Blink Blink
Well we`re half way there.
See you soon for the start of the second half. ThumpUp ThumpUp
(Derek) Admin
#5 Posted : 24 February 2025 21:45:02
Hi All, BigGrin
Here we go with the second half and Issue 61. ThumpUp
Parts supplied.....Pic 1, you will also need the unused part from the previous issue and the main model on the base.
We start with the main model on the base and add 2 x BASE 12 parts as indicated in Pic 2.
Bing the part 26S from the last issue and engage it with part 26B from this issue, as shown in Pic 3. Then secure the parts together, using 3 x MS4 screws as in Pic 4.
We close this update, by adding the detail part 26C as shown in Pic 5.
(Derek) Admin
#6 Posted : 24 February 2025 22:16:46
Hi All, Blink
Here is the final update for this pack with Issue 62 and gets me back up to date with at least one model. Don`t panic though as the next pack is on route as I type. Drool
Parts supplied.....Pic 1, you will also need the final assembly from the previous issue.
Add the new part 26D to the end of the assembly from Issue 61, as in Pic 2. Turn the parts over and secure them together using 3 x MS4 screws, seen in Pic 3.
Finally, add the detail piece 26C as shown in Pic 4, with the assembly at this point shown in Pic 5.
See you soon and keep any unused parts safe until then.
(Derek) Admin
This page was generated in 0.313 seconds.
