As the Moomins build is coming close to finishing, although a lot of work needs doing in the last three pack, I have started designing a few objects for around the house, a sauna for the bath house, pots for the kitchen and I have just today started designing a well for outside. The plan is to have lighting inside the well with a ladder, and when you look down the well it would appear to be quite deep. This will all work with two way mirrors in theory. I have completed the stone design, picture attached. Fingers crossed it all works. Update soon. Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Hi Mark, You are very adept at these things and your skills are admirable. I think I'll just stick to ships. No imagination required.   Chris
goddo wrote:Hi Mark, You are very adept at these things and your skills are admirable. I think I'll just stick to ships. No imagination required.   Chris Thanks Chris, I do like to experiment.
I saw somebody online do a full size one in his house and when you looked down it went on into infinity. 😀
