Stage 43, right side timing belt and pulleys. The belt seems a little on the long side. I know it makes assembly easier but it makes the belt look really loose. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,187 Points: 15,710 Location: ipswich
I also noticed the belts were rather loose. I contemplated cutting a small piece out and gluing with cyano but when the engine is attached to the body you can't really see them anyway.
Looking good though. Keep it coming.
Stage 44. Left side timing belt. This side fits much better then the right side. Maybe a shorter belt? I should have compared them before fitting them to see. Anyway that's pack 9 finished. I have pack 10 here to do now Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 10 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 45. Oil pipe connections They grey pipe (45c) was a little long so I chopped it down a bit. Also be careful when installing pipe 45d and fitting 45e as there are fragile parts involved here. Luckily I didn't break anything🙌 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 46, fuel and oil lines. Part 46f was quite loose so I will leave it off for now until it needs to be connected the other end as I don't want to lose it. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 47, gearbox rear housing Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 48, right gearbox and differential housing Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 49, left gearbox and differential housing. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 50. Engine and gearbox married up. That's pack 10 done now. Waiting for pack 11. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 11 here now Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 51. Gear selector, oil cooler and rain light Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Hi Steve, Coming on nicely, WTG Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Great stuff. Move the oil cooler so it sits central on the supports or the oil pipes won't connect.
Cheers guys. I just rechecked the instructions and it shows the cooler to be offset and the bands go over the raised sections of the cooler which is what I have done. Maybe it will become apparent when I come to putting on the pipes. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 52. Oil tank connections. I found when fitting the black pipe to the 2 pronged fitting in the back of the engine that it was easier to remove the fitting from the engine,fit the black pipe to the correct prong and then fit the fitting back on to the engine. There was a danger of the fitting breaking if i didn't do it this way. Also the oil cooler pipes fitted perfectly so the cooler was in the correct position. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 53. More oil pipe connections Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 54. Left upper rear suspension arm and shock absorber. Where the front of the arm mounts to the gearbox there was a large build up of paint which needed to be removed before it would fit in. Not a biggy though. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 55. Left rear suspension continued Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 56. Left rear hub and drive shaft. That's pack 11 finished. Waiting on pack 12 now Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
