Issue 91
Contents Bathhouse Roof Frame, Pier Steps.
Picture 1 shows the contents for this issue.
Assembling the Bathhouse Roof Frame Separate all the parts using a sharp craft knife, then smooth all the edges. Next paint all the individual pieces. I used the brown paint that was supplied in the first issue, picture 2. Take the large and middle horizontal details along with the short vertical strips and using wood glue attach the parts exactly as shown in picture 3. Allow this to dry before attaching the long vertical strips as shown in picture 4. Finally, attach the small part to the top using wood glue, picture 5.
Assembling the pier steps. Take the five pieces that make up the pier steps, picture 6, and attach all the parts together using wood glue, picture 7.
Attach the steps to the pier from issue 86 using wood glue. This was then painted again using the same colours as I painted the pier, picture 8.
Picture 9 shows the steps with the pier.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 92
Contents Bathhouse Walls and Windows, Pier Steps.
Assembling the Walls and Windows Before we start, you will see that I have inserted the window dividers into the window frames. This was done to make it easier to paint all the windows including the inner dividers.
Take the three wall parts and using a pencil and ruler draw a line to represent individual planks, picture 2. Paint the individual planks with different shades of brown as shown in picture 3. I also applied a semi-gloss varnish once the paint had dried.
Apply some double-sided tape in the centre of the divider, picture 4, and attach the window as shown in picture 5.
Finally, glue all the wall parts together, making sure that they all align including all the chamfers inside and allow to the wood glue to dry.
Pictures 6 and 7 show the assembly complete.
Issue 93
Contents Outer Wall parts, Veranda Side
Fitting the Windows into the wall on the Staircase side Take the three windows assembled in issues 75 and 76, picture 2 and using PVA glue fit the windows into the wall as shown in picture 3. Allow these to dry fully before moving onto the next step.
Next, attach the window frames to the inside using wood glue, picture 4. You will also notice that I have cut some white card and attached these to the wallpaper where they join to each floor. This was my own personal preference as these joins will be seen once the wall are attached.
Assembling the Outer Wall (Veranda Side) Prepare the wall frame from this issue, bending the panels with a ruler as you did in previous issues, picture 5. Using wood glue, line up the panelling to the frame as shown in picture 6. Do the same with the upper panel and glue onto the frame, picture 7. Allow this to dry fully.
If there are any of the panels that need to be glued to the frame when inspecting the assembly from the inside, then use quick drying glue to fix any loose panels to the frame. Attach the two-fixing plate to the inside as shown in picture 8.
Picture 9 shows the completed assembly for this issue.
Issue 94
Contents Outer Wall parts, Interior Wallpaper.
Assembling the Outer Wall (Front Porch Side) Prepare the wall frame from this issue, bending the panels with a ruler as you did in previous issues. Using wood glue, line up the panelling to the frame as shown in picture 2. Do the same with the upper panels and glue onto the frame, picture 3. Allow this to dry fully.
If there are any of the panels that need to be glued to the frame when inspecting the assembly from the inside, then use quick drying glue to fix any loose panels to the frame. Attach the three-fixing plate to the inside as shown in pictures 4 and 5.
Retrieve the wall assembly from issue 93 (Veranda Side) and paint the edges with blue paint as you have done with the previous wall assemblies.
You will also note I have sanded down the assembly and repainted as I did before. Please see posts 89 and 90 for all the notes and painting guidelines if you are doing the same. Picture 6 shows the wall assembly painted.
Take the three interior wallpapers, picture 7 and glue these on the inside of the wall assembly. Picture 8 shows the wallpaper in place. Please note their position and orientation.
Assembling the interior of the house Take all the three floors and start to assemble each floor using wood glue and clamps. Make sure the floor and ceiling tabs all line up, pictures 9 and 10. I would recommend leaving the clamps in place for a good 24 hours before removing them.
Using a craft knife, cut 3 strips of cardboard (5mm wide) from the cardboard supplied with this issue, picture 11, and place them on the edges of the wall ends using double sided tape as shown in pictures 12 and 13.
Issue 95
Assembling the Outer Wall (Front Porch Side) Prepare the wall frame from this issue, bending the panels with a ruler as you did in previous issues. Using wood glue, line up the three panels to the frame, one by one as you have done previously. Allow them to dry fully.
If there are any of the panels that need to be glued to the frame when inspecting the assembly from the inside, then use quick drying glue to fix any loose panels to the frame, picture 2. Attach the remaining fixing plates to the inside as shown in picture 3.
Take the outer assembly (Veranda Side) and fit the windows and doors you made previously from issues 78, 79, 80 and 82. Use PVC glue and allow to dry, picture 4.
Turn the assembly over and take the door surround from issue 79, cutting off the bottom excess with a craft knife. Glue this around the door area. Next, take the window frames from this issue and glue them around the inside of the windows as shown in picture 5.
Retrieve the wall assembly from earlier (Porch Side) and paint the edges with blue paint as you have done with the previous wall assemblies.
Take the three interior wallpapers and glue these on the inside of the wall assembly. Picture 7 shows the wallpaper in place. Please note their position and orientation.
Retrieve the decorating card “B” and cut out two of the 8mm wide strips. Apply double sided tape to the back and place them along the edges of the stairwell as shown in pictures 8 and 9.
Picture 10 shows them both in place.
