Issue 59
The Support
Carefully peel off one of the protective pads (59B) and attach it to the inside of the moving waist clamp (59A), picture 2.
Place the spring into the recess of the movable clamp making sure that one end fits into the slot as shown in picture 3. Fit the fixed clamp over the movable clamp making sure that the other spring end fits into the slot and then secure it with a VM screw, picture 4.
Take the assembled support bar and fit the clamp into the holes in the upper section as shown in picture 5. Turn the assembly over and secure the clamp with 2 x EM screws, picture 6.
Finally fit the lower part of the support into the hole in the base, picture 7.
Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 60
The Waist
The rear waist (60A) is the counterpart to the front waistband. Secure the waistband in place by using 2 x EP screws as shown in picture 2.
Issue 61
The Waist Band
Fit the outer waistband (61A) over the inner waistband. The front of the waistband has a set of grooves which match those of the inner waistband, picture 2.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 62
Chest
Picture 1 shows the chest part which will be assembled in the next pack. Please store this part away carefully.
Picture 2 shows the completed assembly so far.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
