Joined: 13/10/2020 Posts: 171 Points: 522 Location: Hampshire, UK
Ahoi everyone, as usual, progress is slow as time is sparse. But I managed to work a little more on the gallery. I wasn't happy with the share shaped design of the doors leading to the loos. As I only had done two out of six so far, it didn't't bother me too much having to do them again. Now at least they look a bit more than the ones on the Victory with a more rounded shape on the top. I also got rid of the 'frame' design to the left and right of the door, which was a pain to do in the first place. With this simplified design, I saved myself some frustration and time. Odo attached the following image(s):
Now for the upper two levels of the gallery I printed the checkered pattern on photo paper and simply glued it on the upper gun deck planking, which I extended all the way to the end of the gallery. After, I build the partition wall from scrap wood (as there's plenty). For the upper level I bought a 0.8mm basswood sheet and reinforced it with 1x3mm planks glued on top. Odo attached the following image(s):
and the ceiling with the lighting... Odo attached the following image(s):
the idea is that the cables will sit in a cavity between the ceiling and the planking for the poop deck... Odo attached the following image(s):
and a couple of furniture already, of which I build more here and there to add some details to the gallery inside Odo attached the following image(s):
Joined: 25/02/2017 Posts: 340 Points: 1,019 Location: surrey
Looking in on your build. Coming along nicely. Keep up the good work. Andy.
Hi Odo, That is some amazing detailing. Please keep it coming, its a joy to see. Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
That is some very nice work. A lot of thought and planning is gone into that. Mark Regards Markwarren (Mark) Admin
Hi Odo, I have been following your build since you started and it is amazing what you have achieved. Looking back at some of the earlier pics I noticed the high quality of the hull sanding and in particular, the gunport inserts. I know how painstaking these little details are and I wish I had your skills. Keep it coming sir. This is a real lesson in how to do things for modellers of all standards. Chris
 Rank: Semipro Level 1 Groups: Registered
Joined: 23/03/2010 Posts: 70 Points: 213 Location: bristol
Hi Odo you really have a supreme talent for ship building i am in awe of your fine workmanship.
Odo, Love your details that takes skill and a lot of patience you have this looking forward to your next post. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
