 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,058 Points: 15,320 Location: ipswich
On we go.
After some careful dismantling (breaking it apart) the bits were soaked overnight in oven cleaner and washed, then sanded. Now in primer and the cockpit is silver and the seat black. These bits will go back together shortly. roymattblack attached the following image(s):
A little done. Interior parts reassembled and the side pods are now attached to the body panels but only at the upper edge so far. The pods are incredibly warped so I've fixed the upper edge leaving the bottoms free. When the glue is fully set - 24 hours? I'll pull the lower edges in and clamp them, with some glue in the join.roymattblack attached the following image(s):
Hi Roy, You certainly know how to pick em. I`m sure it will end up very presentable in your hands. Good Luck. Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Rank: Pro Groups: Registered
Joined: 25/02/2017 Posts: 340 Points: 1,019 Location: surrey
Another one to test your patients. I’m sure you get through and have a decent model in the end. Andy.
Many thanks you chaps. All good fun.
I've fixed the rear side pods into place now and the body sides are glued at the bottom edge.
I've built enough of these kits now to know the (numerous) pitfalls - one being that when the body tub is assembled, the front frame won't fit.
I'll put the front frame in place when the body lower joins are set, then 'wrap' the body sides around it and then add the upper front deck.
When all is dry, take the frame out again, knowing it will fit later on.
Front frame now mostly sorted and pipework added to it.roymattblack attached the following image(s):
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,864 Points: 20,909 Location: Northamptonshire, England
The amount you’ve done of these type of kits Roy, you ought to start your own repair shop program. Regards Markwarren (Mark) Admin
Not a bad idea Mark. lol.
The body primer has hardened off for a good few days so now it's been masked and had 3 coats of gloss white.
Masking off tomorrow. roymattblack attached the following image(s):
A wee bit more here.
Masking all removed, and I've cut off the protruding piece of the floor at the front of the body. Another bit learned from previous builds of this kit.
If that part stays in place and the kit is built following the instructions, it is literally impossible to fit the pedals as the steering column is in the way, over the top and access through the rectangular hole between the brakes is a joke.
This way, the front cradle can be added and the pedals then fitted to the cut off piece, before being offered up from underneath.
Method in my madness... roymattblack attached the following image(s):
Fuel lines, plug leads etc sorted and now work moves on with the rear end. roymattblack attached the following image(s):
Another update on this one...
Many of the suspension parts were broken but they've been sorted now and assembled. Some pipework added - still lots to go. Exhausts also now added.
Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Well done Roy great don't no how you do it a master at work. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Many thanks Trev.
I'm doing bits of this one every now and then between other stuff so updates are a tad irregular.
Wheels assembled and painted, tyres added and lettering on. I found the rear wing is missing an end plate so I made one from sheet placcy. Luckily it's a simple flat part.
Not so lucky - the dashboard part is missing. I'm going to have to scratch make that bit.
On we go... roymattblack attached the following image(s):
Righty-ho. Replacement dash now sorted.
TBH, I created it it Serif Page Plus, printed it on photo paper and then stuck it to 80 thou plastic. Once cut out, the rear had some gauge bodies added from bits in my scrap box. The bezel on the large gauge is actually a spare 1/43 wheel rim.
I'll add wiring to the back before I fit it in the car.
Ignore the 'speckles' on the dash. In reality, they aren't there.
The home stretch on this one now.
The assorted body parts, wings, air box etc all in white primer awaiting respective top coats. Engine pipework etc all sorted.
I've still got to print the decals but the art is done for them. Another few days should see it sorted.roymattblack attached the following image(s):
Pretty much all the assembly work has been completed - a few detail bits to add - and all the body parts are in primer awaiting top coats of red or white. I'll print the decals today so they should be ready to add tomorrow.
Hmmm... Next project???roymattblack attached the following image(s):
Joined: 10/10/2010 Posts: 689 Points: 2,130 Location: Dorset
Next Project MMMMMMM How about demolishing a large plate of Roast Turkey with all the trimmings. Add to this, a nice glass of something you enjoy. Followed by Xmas Pudding Happy Christmas to all our members Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Sounds like a plan Gil... Especially the last bit.
Decals printed and most of the paint sorted. Hopefully finished later tomorrow or Tuesday.
