Robocop Official Build Pack 15 Options
#1 Posted : 01 December 2024 20:04:28
Issue 55
The Base
Please note that the parts shown in the magazine are slightly different to the parts received. There are no metal support bars.
The Base
Secure the second half of the base from this issue (55B) with the half base from issue 54 (54B) using 3 x EP screws.
The part 55A will be used in the next issue.
#2 Posted : 01 December 2024 20:17:18
Issue 56
The Pelvis and the Base
Retrieve the Robocop assembly and place the pelvis (56A) as shown in picture 2. Turn the assembly around and secure in place using 3 x EP screws, picture 3.
Retrieve the part 55A from the last issue and push fit to the right-hand side over the screw you have just placed, pictures 4 and 5.
The Base
Take the base assembly and fit the last connector (56B) using 2 x EP screws, picture 6.
Picture 7 shows the complete assembly for this issue.
#3 Posted : 02 December 2024 21:23:27
Issue 57
The Waist and the Base
Fit the lumbar joint (57D) into the lower lumbar joint, picture 2 and secure it with a CP screw, picture 3.
Place the lower lumbar joint support (57C) in position, checking that it fits correctly, picture 4. Now retrieve the waistband assembly from issue 53 and fit in place as shown in picture 5. Secure the assembly using 4 x EP screws, picture 6.
Fit the screw cap (57B) into position as you did in the last issue on the opposite side, picture 7.
Finally, fit the two connectors (57A) over the guide rails on the underside of the base as shown in pictures 8 and 9.
#4 Posted : 04 December 2024 19:50:58
Issue 58
The Pelvis and Support
Fit the screw cover (58C) into the lower seat as shown in pictures 2 and 3 .
Carefully peel off one of the protective pads (58B) and attach it to the waist clamp (58A) which will eventually attach to the vertical support bar out of RoboCop’s base, picture 4.
This page was generated in 0.194 seconds.
