Optimus Prime Official Build Pack 15 Options
#1 Posted : 16 October 2024 19:25:11
Issue 67
Assembling the Left Arm.
Picture 1 shows the contents of the parts for this issue.
Fit the elbow plate (67F) into the elbow bend post and align the holes as shown in picture 2. Align the pin (67G) with a pair of pliers or tweezers and push the pin through the hole, picture 3. You will need to push the pin all the way in. I used the back of a small pair of pliers to do this. The pin can be quite stiff to push in, so be careful not to damage any of the parts, picture 4.
Snap the arm plate (67D) into position connecting the three pins in front of the arm, pictures 5 and 6.
Fit the arm coil ball joint (67E) over the end of the coil (67A) and secure the parts with a YP screw, picture 7. Push fit the arm coil joint onto the top of the outer side of the arm, picture 8.
Place the arm outer disk (67C) on the circular part of the arm coil, making sure the inner notch of the disk matches the tab on the coil. Secure with a KP screw, picture 9.
Finally, snap the arm outer disk cover (67B) in place in the orientation as shown in picture 10.
#2 Posted : 17 October 2024 19:45:28
Issue 68
Fit the barrel front cover (68B) and rear barrel cover (68A) on the shoulders of the barrel body, picture 2. Note that the small slot on the side is closer to the back. Now fit the front cover trim (68F) onto the front cover, pictures 3 and 4.
Fit the arm cap (68J) onto the support arm (68G), then position the arm as shown in pictures 5 and 6.
Position the barrel joint (68D) and fit it onto the barrel support arm and secure it with a ZP screw, pictures 7 and 8.
Now fit the retaining plate (68I) onto the rear pin as shown in picture 9, then place the support cap (68H) onto the end, aligning the internal pin with the groove, picture 10. Add the side plate (68E) to the assembly as shown in picture 11.
#3 Posted : 20 October 2024 17:32:58
Issue 69
Fit the forearm back plate (69D) over the lower back plate (68G), pictures 2 and 3. Fit the back plate in the two upper holes in the lower back plate (69A), picture 4. Attach the detail (69E) into the next two holes, picture 5. Align and fit the detail (69H) to the lower part of the plate as shown in picture 6, then add the round side detail (69F), picture 7.
Take the arm assembly and attach it to the plate assembly and fit the two pins in the forearm area, pictures 8 and 9.
Fit the round to detail (69I) into the forearm front plate (69C), pictures 10 and 11 and then the side plate (69B) into the two corresponding holes as shown in pictures 12 and 13.
Finally fit this assembly to the arm as shown in pictures 14 and 15.
Picture 16 shows the complete assembly for this issue.
#4 Posted : 21 October 2024 19:34:13
Issue 70
Take the smaller circular plate (70C) and the larger circular plate (70D) and attach them to the outer forearm armour (70A). Then push fit the lower plate (70B) in place as shown in picture 2.
Next fix the assembly into the arm as shown in pictures 3 and 4.
Note: Be careful when pushing the assembly onto the arm and not to press the piece on the opposite side.
Attach the bottom plate (70E) as shown in pictures 5 and 6.
Pictures 7 and 8 show the complete assembly for this issue.
#5 Posted : 22 October 2024 20:17:05
Issue 71
Snap fit the cover (71B) onto the shoulder plate (71A), pictures 2 and 3. Then inside the plate 71A place the inner plate (71C) and secure it with 2 x IP screws, pictures 4 and 5.
Take one of the parts (71F) and part (71G) and fit one of the shorter pins (71H) as shown in pictures 6 and 7, pushing in the pin smooth side first, picture 8. Repeat the same operation with the upper outer joint (71J), picture 9.
Insert the connector (71I) into the assembly connectors noting their orientation and secure the three pieces with the long pin (71K), picture 10.
Carefully fit the outer joint plate (71D) into the holes on the flat side of the connectors, picture 11.
Insert the joint connector assembly into the inner joint (71E) and secure with a QM screw as shown in picture 12. Now press this assembly onto the shoulder plate, pushing the pins in the holes, picture 13.
Note: If you have trouble getting the pins in place as I did, you can undo the inner shoulder plate screws, attach the assembly and then re-attach the inner shoulder plate with the screws.
Now place the complete assembly to the left arm and secure with an AM screw on the opposite side as shown in pictures 14 and 15.
Pictures 16 shows the complete assembly for this issue.
This page was generated in 0.347 seconds.
