One thing the Moomin’s house does not have is a door to the cellar. The natural place for this to be is to place it under the stairs, because the pull out cellar compartment already has the steps.
I have designed a doorway which will be laser cut using 2mm plywood and 4mm moulded plywood for the door frame. Here are a couple of pictures to show the sketch of the door and where it will be placed.
I’ll post more pictures once it is in place.
MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
