LOTUS 97 Stage 19 instructions error Options
#1 Posted : 23 August 2024 11:32:40
Stage 19 shows how to fit part 19F - Fuel tank breather hose, and part 19J - Fire extinguisher pull cable.
The parts list image on page 5 of the magazine shows incorrect parts for both pieces.
19F is shown as a longer black pipe when it is actually a shorter white pipe as supplied.
19J is shown as a shorter black pipe when it should be a longer black pipe as supplied.
The actual build instructions show the correct parts being fitted.
If you follow the parts list, you will fit a long pipe to the breather, leaving a pipe too short for the pull cable.
In a few instances, the parts supplied have both been black.
This will not really matter as long as the correct long and short pipes are fitted in the correct places.
Steve279021
#2 Posted : 23 August 2024 18:33:19
Or like me, you end up with a short black one and a short white one
Dodge charger build complete
This page was generated in 0.114 seconds.
