As you all know, I'm building the Moomins house. Now I'm getting closer to the finishing line, I've decided to make a base for the house to sit on and make a little garden with grass and flowers. Although I'm not quite ready to make the base until most of the outside of the house is built, I've started to think what could go in it. My ideas are a swing, sand pit, plant pots and a couple of deckchairs. I've designed the deckchair and laser cut the parts out using 1.5mm plywood. I also have a lot of striped cloth. Test printed and make the first one. Quite pleased with how it turned out. Amazingly, I can never put a real one up.
MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
That's going to be a nice touch to the Moomin's House, Mark. Beautifully made. How about a parasol to go with it? Chris
Parasol coming up Chris, just did this over the weekend. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Fabulous build Mark. Could do with a pair of flip flops? Chris
goddo wrote:Fabulous build Mark. Could do with a pair of flip flops? Chris COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
