Joined: 26/04/2014 Posts: 1,397 Points: 4,100 Location: Essex
Stage 7, nose cone and gear shift Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 8, main chassis and cockpit detail. Pack 3 finished, waiting on pack 4 now Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Rank: Advanced Member  Groups: Registered
Joined: 04/03/2024 Posts: 36 Points: 111 Location: Kent
Coming along nicely.  Looking forward to receiving 6 parts per pack.
Yes, won't be long. They've just taken the payment for my 4th pack Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 4 here now👍 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Hopefully🤞. Need to find the time! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Steve279021 wrote:Hopefully🤞. Need to find the time! You`ll find the time, modellers always do.
Regards delboy271155 (Derek) AdminCOME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Yep, you're right, I found a bit of time to do 1 stage tonight. Stage 9, cockpit bulkhead and steering. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 10 done. Front suspension Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 11 done. Front suspension continued and shocks Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 12 done. Roll bar and pedals Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Yep, you always find time when you say that you haven't got any!😂 Cheers Derek👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 13. Clutch and brake controls. Wow, this was fiddly! I found that the reservoir on the right side of the chassis was loose in the master cylinder and the 2 top caps where also loose in the reservoir tops. I will probably glue them in but I haven't got any at the moment so I'll leave it out of the main chassis until I get some. Also I found that the pipe from the little blue fitting on top of the clutch master cylinder to the floor was a little long so I chopped off a couple of mm. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 13 complete. Front suspension fitted to the chassis Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That's stage 14 and pack 4 done. Cockpit side panel, side chassis brackets and front left hub carrier fitted. A couple of small issues, firstly the centre pin on the cockpit panel was really tight and it broke off making the panel a bit loose so used a little glue where the snapped off pin was. Secondly, the pin on the front hub that goes onto the end of the steering arm was too tight so I had to file the pin down a bit so it would go in the hole. Anyway, waiting for pack 5 now Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Hi Steve,
Looks like you found some more time and the build looks all the better for it.
WTG
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,061 Points: 15,329 Location: ipswich
It's great to see another Lotus on the go. Glad you sorted your little problems. I'm just awaiting parts so I can continue the official build. A superb kit.
