12 Pages <1234>»
My Senna 97T build Options
Steve279021
#21 Posted : 28 June 2024 13:27:03
Stage 7, nose cone and gear shift
Steve279021 attached the following image(s):
Dodge charger build complete
Steve279021
#22 Posted : 30 June 2024 15:06:05
Stage 8, main chassis and cockpit detail. Pack 3 finished, waiting on pack 4 now
Graham27
#23 Posted : 03 July 2024 17:36:10
Rank: Advanced Member
Coming along nicely. ThumpUp Looking forward to receiving 6 parts per pack. BigGrin
Steve279021
#24 Posted : 03 July 2024 20:01:20
Yes, won't be long. They've just taken the payment for my 4th pack
Steve279021
#25 Posted : 16 July 2024 14:14:59
Pack 4 here now👍
#26 Posted : 16 July 2024 20:03:18
Hi Steve,
Drool Drool Drool Drool Drool
Hope to see some updates soon then.
No Pressure, LOL
(Derek) Admin
Steve279021
#27 Posted : 16 July 2024 20:18:25
Hopefully🤞. Need to find the time!
#28 Posted : 16 July 2024 20:26:05
You`ll find the time, modellers always do. ThumpUp
(Derek) Admin
Steve279021
#29 Posted : 16 July 2024 22:13:57
Yep, you're right, I found a bit of time to do 1 stage tonight. Stage 9, cockpit bulkhead and steering.
Steve279021
#30 Posted : 17 July 2024 21:47:04
Stage 10 done. Front suspension
Steve279021
#31 Posted : 18 July 2024 18:28:27
Stage 11 done. Front suspension continued and shocks
Steve279021
#32 Posted : 18 July 2024 18:51:31
Stage 12 done. Roll bar and pedals
#33 Posted : 18 July 2024 19:05:16
WOW Steve, Cool
See you found some more time then. LOL LOL
Looking good, WTG.
(Derek) Admin
Steve279021
#34 Posted : 18 July 2024 22:36:07
Yep, you always find time when you say that you haven't got any!😂
Cheers Derek👍
Steve279021
#35 Posted : 19 July 2024 16:37:41
Stage 13. Clutch and brake controls. Wow, this was fiddly! I found that the reservoir on the right side of the chassis was loose in the master cylinder and the 2 top caps where also loose in the reservoir tops. I will probably glue them in but I haven't got any at the moment so I'll leave it out of the main chassis until I get some. Also I found that the pipe from the little blue fitting on top of the clutch master cylinder to the floor was a little long so I chopped off a couple of mm.
Steve279021
#36 Posted : 21 July 2024 18:13:34
Stage 13 complete. Front suspension fitted to the chassis
Steve279021
#37 Posted : 21 July 2024 19:17:20
That's stage 14 and pack 4 done. Cockpit side panel, side chassis brackets and front left hub carrier fitted.
A couple of small issues, firstly the centre pin on the cockpit panel was really tight and it broke off making the panel a bit loose so used a little glue where the snapped off pin was. Secondly, the pin on the front hub that goes onto the end of the steering arm was too tight so I had to file the pin down a bit so it would go in the hole.
Anyway, waiting for pack 5 now
#38 Posted : 22 July 2024 18:27:48
Hi Steve, Cool Cool
Looks like you found some more time and the build looks all the better for it.
WTG
(Derek) Admin
Steve279021
#39 Posted : 22 July 2024 18:34:44
Cheers Derek👍
#40 Posted : 23 July 2024 11:48:07
It's great to see another Lotus on the go.
Glad you sorted your little problems.
I'm just awaiting parts so I can continue the official build.
A superb kit.
12 Pages <1234>»
This page was generated in 0.398 seconds.
