Infinity Gauntlet Official Build Issues 62 - 66 Options
#1 Posted : 19 June 2024 17:24:02
Hi All, BigGrin
This was a little sooner than I expected, but the next pack of the Infinity Gauntlet arrived this morning. This the 14th pack in the series and covers issues 62 - 66. These issues build up the inner forearm of the Gauntlet, that started with issues 60 and 61.
Parts supplied.....Pic 1. You will also need the assembly from the end of issue 61.
Bring the assembly from issue 61 and add the part A76 to it, Pic 2. NOTE: Make sure that the parts are fully engaged before you proceed to the next step.
You now need to secure the parts using 5 x type 01 screws, Pic 3. ALSO NOTE: These screws may lock up before the parts are firmly held together. Should this happen, unwind the screws a couple of turns and then tighten again.
That`s all there is for this update, so I`ll see you soon for Issue 63.
(Derek) Admin
#2 Posted : 21 June 2024 14:52:56
Hi All, BigGrin
Here we are with the next addition to the Gauntlet. Issue 63. Much the same as the previous update, where we add the next plate to the inner forearm.
Parts supplied.....Pic 1. You will also need the assembly from issue 62.
Engage part A77 fully with the assembly from issue 62. Pic 2. Then whilst keeping the parts firmly together, fix them using 5 x type 01 screws. Pic 3.
That`s it for this update, Pic 4 shows how the outside of the armour looks now.
Take care and see you soon. ThumpUp
(Derek) Admin
#3 Posted : 23 June 2024 15:29:30
Hi All, BigGrin
Back with the next update for the Gauntlet, Issue 64. Very much the same as the last update where we extend the inner forearm plates.
Parts supplied.....Pic 1, you will also need the assembly from Issue 63.
Position the new part A78 to the assembly from issue 63, Pic 2.
Fix the part using 5 x Type 01 screws, Pic 3. Remember, if the screws lock up before the parts are closed together, back the screw off half a turn and tighten again.
That`s all for now, Pic 4. Issue 65 coming soon.
(Derek) Admin
#4 Posted : 25 June 2024 17:11:56
Hi All, BigGrin
We`re on to Issue 65 of the Gauntlet, where we will extend again the Inner Forearm.
Parts supplied.....Pic 1, you will also need the end assembly from Issue 64.
Ok, so this is very much the same again. Blink
Position the part A79 to the assembly from issue 64, Pic 2.
Fix part A79 using 5 x type 01 screws, Pic 3.
That`s all for this update, Pic 4.
In the next update (last one for this pack), we will complete the Inner Forearm part of the armour.
(Derek) Admin
#5 Posted : 27 June 2024 21:35:17
Hi All, BigGrin
Here we go with the last update for this pack, Issue 66. This completes the main section of the inner forearm.
Parts supplied.....Pic 1, you will also need the assembly from issue 65.
Position part A80 to the assembly from issue 65, Pic 2. Then fix it in place using 5 x type 01 screws, Pic 3.
YEP, you guessed it that`s it for this update, Pic 4. It may be noted that the top edge of this assembly (the wrist area) does not fit tightly together. There are more parts to fit in that area that will draw them together.
See you all soon, when the next pack arrives. ThumpUp
(Derek) Admin
This page was generated in 0.249 seconds.
