DELOREAN INSTRUCTIONS ERROR Options
#1 Posted : 23 May 2024 13:15:31
Just a heads-up for those building the BTTF DeLorean.
Stage 16 shows in the printed instructions, a cut-out and two locating screw holes in the left transmission case, part 16A.
The cut-out and the holes do not exist on the actual kit part.
The printed instructions go on to show part 16D, the lower pan, being fitted.
This part also does not exist.
Assembly of the kit has been modified at some point but the instructions were not updated.
The attached pictures show the instruction page with the errors pointed out with red arrows, and the actual kit part as supplied.
YOU ARE NOT MISSING PART 16D.
This page was generated in 0.089 seconds.
