Need Help Please Options
GhostyJHH
#1 Posted : 22 April 2024 01:59:58
Rank: Newbie
Hi,
So i have a huge issue i cant figure out, im finally getting round to finishing robi (after numerous replacement parts and a house move), im upto testing the limbs
Robi's right arm functions fine no issues (except battery dying)
Robi's left arm does nothing (fully charged battery)
Robi's right leg does nothing (fully charged battery)
Robi's left foot/ankle does nothing (fully charged battery)
I have stripped all parts, checked all servos are correctly numbered and all wires are correctly seated.
I have 2 main boards, 2 test sd cards, 2 power supply boards, 3 power adaptors (2 uk, 1 eu (i think)), 3 batterys. I have tried all combinations i can think of with the same results.
Can someone please help me figure this out
Im aware ill probably need a new battery at some point, but as i can get right arm functioning i know theres enought juice to test it with.
#2 Posted : 22 April 2024 12:11:06
Hi Ghosty,
Well this is a blast from the past. The Official Build ended in December 2016.
Blink Crying Blink
That said I do remember a problem on the same lines. It was down to the wire routing not having the slack in the right place, so it stopped the limb motion.
After a quick search I found a previous post. Unfortunately the Gentleman that built the Official Build is no longer available on the forum, so I have put a link below to his explanation.
Hope this helps:
https://forum.deagostini...amp;t=28878&__utma=
(Derek) Admin
GhostyJHH
#3 Posted : 24 April 2024 17:45:48
Rank: Newbie
Hi,
Thanks for the reply, i have read the post you suggested, most of this i had already done, his seems fully built where as mine is still at testing phase however the processes would require less work.
This is really starting to bug me now.
#4 Posted : 24 April 2024 18:36:27
GhostyJHH wrote:
Hi,
Hi Ghosty
Below is a link to the Official Build. Don`t know if there will be something in there to help? Or its a trawl through the ROBI discussion area of the forum.
https://forum.deagostini...s&f=298&__utma=
(Derek) Admin
This page was generated in 0.137 seconds.
